axle vibrations.
Old Mar 10, 2008 | 02:03 AM
E-AT_me's Avatar
Default axle vibrations.
ok, i had an axle vibration under load, so i went ahead and replaced both axles due to both of them losing grease at the inner joint. now i have a strange vibration at around 3000 RPM. it doesn't really have anything to do with speed, more RPM. the only thing i did was change axles. i'm confusd. i'm going to attempt to switch to the old axles one at a time and see if that affects anything. it's very strange, but i'm pretty sure it's the axles. cause if i hold it at the RPM, and saw the wheel, it sounds as though the pavement is grooved. when it's not... any recommendations?
Old Mar 10, 2008 | 03:14 AM
E-AT_me's Avatar
Default Re: axle vibrations. (E-AT_me)
btw, it's on a bone-stock 91 Civic Si.
Old Mar 10, 2008 | 07:50 AM
Hanmin's Avatar
I think that if it's vibrating with the rpm, it shouldn't be the axles, something closer to the engine or more engine related, mounts maybe?
Old Mar 10, 2008 | 09:51 AM
E-AT_me's Avatar
Default Re: (Hanmin)
that's what one would think, but this only happened AFTER i replaced the axles. this definately wasn't happening beforehand.
gettinmoneyny
Jul 2, 2010 08:30 PM
VDM_DC2
Suspension & Brakes
11
Oct 28, 2009 12:28 PM
SwissChEz82
10
Nov 21, 2008 11:44 AM
cd5_2NR
Feb 24, 2005 11:54 PM
hybrid901
Jun 3, 2002 11:42 AM
