Any way to hold the auto tensioner for the timing belt closed without the stopper tool?
Old Mar 10, 2008 | 01:17 AM
H22Stew's Avatar
Default Any way to hold the auto tensioner for the timing belt closed without the stopper tool?
As the topic says, is there any way to hold the timing auto tensioner closed while it's being installed without the honda stopper tool? The local dealer wants 25$ for it, and hondaautomotoveparts is about the same with shipping. Just trying to save a buck
Thanks
Old Mar 10, 2008 | 04:57 AM
mgags7's Avatar
You should be replacing that tensioner with a new part, and they come with the stopper already on them.
If you insist on reusing it, which is a horrible idea, you can use zipties to do it, two in an crossed pattern will do it.
Old Mar 10, 2008 | 09:29 AM
H22Stew's Avatar
Default Re: (mgags7)
The new ones come with the stopper? Awesome.
Old Mar 22, 2008 | 08:34 PM
jdmh22na's Avatar
Default Re: Any way to hold the auto tensioner for the timing belt closed without the stopper tool? (H22Stew
we just did the swap this weekend. put it in a vice. screw the tensioner back and hold the screwdriver there until someone puts 2 zip ties around it. slowly let loose then screw the nut back on. it should work long enough to put in. then bolt in the other 2 screws on the block and snip the zip ties. redneck stopper but it worked.
Old Mar 23, 2008 | 08:30 PM
CHK4TIX's Avatar
I dont have a pic but I made my own tool out of a the door handle bracket from a honda civic, works perfectly.
Old Mar 24, 2008 | 08:39 AM
prelude1897's Avatar
I'd highly suggest changing the tenisoner instead of reusing yours
Steve and Nikki
Dec 11, 2010 02:56 PM
jk11blueboi
Feb 2, 2007 06:51 PM
HOLDEM1981
Apr 12, 2005 03:34 PM
david90
Oct 1, 2003 02:13 PM
david90
Aug 30, 2003 07:32 PM
