i have a question about the hasport cable to hydro mount kit
I need to know which L bracket is being used for the cable to hydro mount kit for a bseries motor into a crx. i tried the 94-2000 integra l bracket it seems to be off a little bit. I using a 1995 gsr tranny. If some has used this please help me out thanks.
Just finished that same swap not to long ago. Used the 90-93 integra t bracket.
*don't forget you have to beat the frame downward so the bracket fits right...
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by allmotor1313 »</TD></TR><TR><TD CLASS="quote">I need to know which L bracket is being used for the cable to hydro mount kit for a bseries motor into a crx. i tried the 94-2000 integra l bracket it seems to be off a little bit. I using a 1995 gsr tranny. If some has used this please help me out thanks.</TD></TR></TABLE>
You will need to use the 90-93 Integra bracket
You also need drill the bottom holes out with 9/16ths bit to accept the bigger hydro bolts
thanks everyone and to hasport i drilled the hole out on the t bracket and it fits fine now thanks.
revikan
Sep 2, 2010 04:27 PM
