Amp hooked up, but not working? *Help!*
Old Mar 9, 2008 | 10:16 PM
SunnyTO's Avatar
Default Amp hooked up, but not working? *Help!*
ok so I installed an amp and sub in a 6th gen Accord today and here:
1. connected the power to the battery with the inline fuse and connected to the amp *check*
2. remote wire connected to the blue with white line behind the deck *check*
3. rca connected to the (sw) outputs at rear of deck *check*
4. rca connected to the amp *check*
5. ground cable bolted to the seat belt bolt *check*
6. ground connected to the amp *check*
7. speaker wires connected (check)
now, the problem is when all connected as previously stated above the amp does not even light up (has a led that shows power is on)
But, when i disconnect one of the rca plugs and just touch the amp case I get power and random bass......????wtf
this system/set up used to work on a previous car the only diff's are the wires.
-could it be the rca cables?
fyi. its a 2channel amp and a single 12inch sub JL
thanks for any advice
Old Mar 10, 2008 | 04:44 AM
B18C_EJ8's Avatar
How's that seatbelt bolt you grounded to? Nice & rusty & corroded?
Have you verified with a meter or test light that you're getting 12v at the main power wire at the amp and that you get 12v when you turn the deck on?
Old Mar 10, 2008 | 05:09 AM
White Smoke's Avatar
i my honda
Global Mod
Default Re: Amp hooked up, but not working? *Help!* (SunnyTO)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by SunnyTO &raquo;</TD></TR><TR><TD CLASS="quote">
But, when i disconnect one of the rca plugs and just touch the amp case I get power and random bass......????wtf </TD></TR></TABLE>
What do you mean touch the amp case? Touch it with what? Do you have access to a volt/ohm meter? Have you tried using another ground source? Have you ensured that none of your power or speaker wires are shorting to each other?
froogle29
Audio / Security / Video
Oct 29, 2009 07:44 PM
ws350z
Sep 21, 2008 07:59 PM
accord64
Oct 3, 2007 08:19 PM
special_edition
Feb 3, 2004 03:31 PM
intenseEK
23
Dec 17, 2003 06:54 PM
