I have no pressure on my brakes...
Old Mar 9, 2008 | 09:29 PM
integobsession's Avatar
Default I have no pressure on my brakes...
I changed out the calipers today on my minivan. But there's no pressure - meaning that the brakes hit the floor with very minimal resistance. I've never chnaged them before by myself but I figured I would just give it a try... There were only three bolts I had to unscrew in order to put in the new ones so I know I couldn't have messed that up.
However, there are two things I believe I may have done wrong. One is I screwed the bolt that holds the brake line to the caliper extremely tight. The other is I didn't bleed out the system... only because I don't know how.
So basically it might be one or the other or maybe even both. So the question is how do I fix it? Specifically how do i bleed the brake lines? This is extremely important as I need to use the car tomorrow for work.
I've searched but I'm horrible at it...
Old Mar 10, 2008 | 07:58 AM
mudtracker's Avatar
Default Re: I have no pressure on my brakes... (integobsession)
to bleed the system u must shut the key off and have a second person to sit inside
u tell them to mesh the pedal to the floor and hold it while u slightly open the bleeder on the caliper air and fluid should come out when it stops flowing u tightin the bleeder and they let up on the pedal
repeat until u have just fluid comeing out of the bleeder then go to the other side
P.S. always start on the brakes furthest from the master cylinder, that need to be bled
Old Mar 10, 2008 | 08:22 AM
Crazydave's Avatar
Default Re: I have no pressure on my brakes... (mudtracker)
whenever you open the lines for a brake system you MUST bleed it.
So especially when you replace the calipers, you will need to bleed it.
Make sure the master cylinder didn't go dry either, or you will have to bleed that too
Old Mar 10, 2008 | 12:17 PM
projecthatch92's Avatar
yeah, you need to bleed the brakes. it's really not that bad. just like everyone else said you need a partner with you to help you out
Old Mar 11, 2008 | 10:03 AM
Default Re: (projecthatch92)
Thanks for the replies... I bled the brakes and everything is working perfectly....
bboysake
Suspension & Brakes
Feb 20, 2010 07:37 AM
cityofcaterpillars
Jan 31, 2010 03:06 PM
ant$missShift
Jul 29, 2008 12:11 PM
Integraxnyc
Apr 13, 2004 02:19 PM
GruvyTune
Aug 28, 2001 11:33 AM
