will an OBD1 LS ECU work in place of OBD1 GSR ECU for smog?
Old Mar 9, 2008 | 09:03 PM
egg_baLLa's Avatar
Default will an OBD1 LS ECU work in place of OBD1 GSR ECU for smog?
i have a gsr swap in my 93 civic and i want to know if an obd1 LS ecu would help me pass my smog test? a couple years ago i brought my car in to a test only station and i passed no problem with obd1 gsr ecu, but i dont have it anymore. however i do have an LS ecu.
here are my numbers:
............................HC(PPM)............... CO(%).........................NO(PPM)........RESUL T
M1: 15 MPH........[89]...[263]............[0.53]...[5.30].............[708]...[364]..........GP
M2: 25 MPH........[54]...[271]............[0.51]...[5.34].............[746]...[555]..........GP
so what do u guys think? being the idiot i am i forgot to change ECUs and used my chipped p28 for the test. do u think i'll be able to pass with an LS ecu? or should i try to find a gsr ecu?
Old Mar 10, 2008 | 02:38 PM
egg_baLLa's Avatar
Default Re: will an OBD1 LS ECU work in place of OBD1 GSR ECU for smog? (egg_baLLa)
anyone?
Old Mar 10, 2008 | 04:15 PM
mrdeezy's Avatar
I think you need a lot more help than an ECU
Old Mar 10, 2008 | 04:38 PM
Relic1's Avatar
find someone to loan you a P72 for the day.
And maybe buy it, that chipped P28 is not doing you any good. Tuning should take care of that though...
all though cali emissions is going to fail you instantly with an ECU that's not matched to the engine.
Old Mar 10, 2008 | 04:55 PM
egg_baLLa's Avatar
Default Re: (Relic1)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by mrdeezy &raquo;</TD></TR><TR><TD CLASS="quote">I think you need a lot more help than an ECU</TD></TR></TABLE>
well i think the ecu would help out a lot.. maybe switch out the o2 sensor and cat
but the answer im really after is if the LS ecu could be used in place of the GSR ecu?
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Relic1 &raquo;</TD></TR><TR><TD CLASS="quote">find someone to loan you a P72 for the day.
all though cali emissions is going to fail you instantly with an ECU that's not matched to the engine.</TD></TR></TABLE>
that's easier said than done. i know a lot of friends who had gsr but have since sold it for luxury cars. the ECU is definitely the main culprit in my test failure.
i also have a jdm obd2 p72 ecu.. think that'll work?
Old Mar 11, 2008 | 07:44 AM
Relic1's Avatar
the JDM P72 should work, as long as you have the knock sensor wired up.
And provided you have an OBD2a to OBD1 harness.
'00DC2
Northern California
Oct 19, 2010 06:42 PM
Dokta
Northeast (Sales)
Dec 25, 2009 02:05 PM
b00sted4dr
Feb 7, 2008 09:17 AM
Spracer03
Jan 22, 2008 08:16 AM
jdm.ej
Jun 24, 2005 11:26 AM
