Compression Ratio for 5th Gen
On a stock engine does anyone have the compression ratio and the values so I can enter them in a new calculator I picked up? Need the numbers for the items below...thanks!
Bore/Stroke Designation Type
1 = Inches 2 = Millimeters = 2(mm)
Cylinder Bore Size = ?
Piston Stroke Length = ?
Head Gasket Bore Diameter = ?
Compressed Head Gasket Thickness =?
Combustion Chamber Volume In CCs =?
Piston Dome Volume In CCs Negative For Dished Pistons (Use '-') = ?
Piston Deck Clearance Negative If ABOVE Deck (Use '-') : = ?
Actually, it's 9.5 in the 97 & 98 models and they upped the comp in 99 to 10:1 to bring the HP rating to 200. As far as the OP, don't know, might be in the Helms, though.
B18 CYA
11
Jul 28, 2006 06:24 PM
Takumi Fujiwara
26
Apr 16, 2005 04:22 AM
