TSX projectors
hidplanet.com/forums has the most reliable and readily available projectors.
Ebay, they can be found for cheap as well. Expect to pay around 150 for a pair- make sure to check that they're the right projector, and check to see if the lens is fresnel or totally clear. You should be able to tell in the pictures.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by kp99 »</TD></TR><TR><TD CLASS="quote">How can you tell if it's either fresnel or clear lens?</TD></TR></TABLE>
The pictures
clear is... *gasp* clear
fresnel is rippled/opaque/ .... NOT CLEAR.
The pictures
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by kp99 »</TD></TR><TR><TD CLASS="quote">Do you know what year the fresnel was replaced by the clear lens? Do you have any pictures of these two lenses?</TD></TR></TABLE>
2006 & go into the lighting forum.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by gus738 »</TD></TR><TR><TD CLASS="quote">do the tsx projectors fit like glove in the oem headlights or do you still require to cut around it?</TD></TR></TABLE>
no projector will NOT require cutting.
hmm i dont know if i explained it right or if i understood right. my question is if i get these projector lense and try to put it around the oem headlights or aftermarket headlights would i require to cut around the headlight so it fits properly?
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by gus738 »</TD></TR><TR><TD CLASS="quote">hmm i dont know if i explained it right or if i understood right. my question is if i get these projector lense and try to put it around the oem headlights or aftermarket headlights would i require to cut around the headlight so it fits properly?</TD></TR></TABLE>
You mean into the body of the car or the headlight housing?
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by gus738 »</TD></TR><TR><TD CLASS="quote">yes into the headlight housing, a retrofit i sopposed?</TD></TR></TABLE>
Yea, the projector is a unit; it's a reflective bowl and a lens, with a cutoff shield sandwiched in between, and you retrofit this whole component into a headlight by cutting it and making room for it. The good thing is you can retain factory aiming screws so you can align the beam when you're done.
hidplanet.com/forums has some good instruction and people that have done many retros. Lots of good reading material.
WHITE HYBRID EG6
22
Apr 25, 2004 09:29 PM
