why is the left side of my EK lower than the ride side?
hi guys.
i just wanna ask why the left side of my EK lower than the right side?
how can we fixed this?
tia.
Modified by JDM 101 at 3:56 AM 3/10/2008
Modified by JDM 101 at 3:57 AM 3/10/2008
tia.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by JDM 101 »</TD></TR><TR><TD CLASS="quote">hi guys.
i just wanna ask why the left side of my EK lower than the ride side?
tia. </TD></TR></TABLE>
IS this only when you sit in it? are you 300lbs?
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Crx Jimmy »</TD></TR><TR><TD CLASS="quote">
IS this only when you sit in it? are you 300lbs?</TD></TR></TABLE>
lol ouch
lol ouch
you could also check the the upper ball joint or the bump stop also or you could have beant the spring. Hads a freind with the same prob his was just a matal peice that go's on the strut that wore out so you might wana check that out to.,
mine is like this also..i found out that one of the rear upper bump stop or wutever wasnt sittin correctly when the guy installed the aftermarket shocks when he had the car...i can fit 1 finger under the front wheel well on one side and on the other side i cant fit anything under the other side
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by civiccoupe94 »</TD></TR><TR><TD CLASS="quote">your left shocks might be blown. check if there is fluid leaking from there.</TD></TR></TABLE>
i just change the shocks.
no sir.
im just 130lbs. when i measure the fender gaps on all for corners. the front left side is lower a half and inch. while the rear left side is 3/4 inch lower.
no sir.
WTF is the ri(d)e side
right
well over time **** happens like my car(eg hb) has subs in the back and my car looks like I jacked up my front end but its worth seeking peoples alarms go off
the best thng to do is take the wheel of and visually inspect it for loose worn or incorrect parts or do a bounce test to see if ur springs or shocks are bad
right
sorry sir.
typo error.
anyway, i already change all the rubber bushings to Energy Suspension but still the right side is lower.
typo error.
well there's only 2 contact points
the shock tower, and control arms, they could be bent or dented very rare unless accident has occurs, or your shocks and springs are bad get a freinds shock and put it on see what happens
