URGENT!!! please help you guys.
Old Jul 7, 2002 | 07:09 PM
CalvitoSol's Avatar
Default URGENT!!! please help you guys.
hi, i had this problem of having the top of the #4 spark plug fill up with oil. Because of this, i got the valve cover gasket and o-rings changed. after a while i checked again just to see and it filled up again! i used honda bond and everything again to make sure its a firm seal but nothing seems to fix it. any suggestions? can this be something else? hopefully nothing big? thanx
Old Jul 7, 2002 | 07:46 PM
tinkerbell's Avatar
Default Re: URGENT!!! please help you guys. (theory48)
maybe the rocker cover is damaged?
Old Jul 7, 2002 | 07:59 PM
CalvitoSol's Avatar
Default Re: URGENT!!! please help you guys. (tinkerbell)
rocker cover?
Old Jul 7, 2002 | 09:06 PM
tinkerbell's Avatar
rocker cover = valve cover
[Modified by tinkerbell, 4:06 PM 7/8/2002]
Old Jul 7, 2002 | 09:35 PM
Kamin's Avatar
it could be aLOT worse than a valve cover
if you dont know what your doing, i suggest taking it somwhere
it could be a valve guide. could be a damaged valve seal, bent valve, bad head gasket.
Old Jul 7, 2002 | 09:38 PM
tinkerbell's Avatar
Default Re: URGENT!!! please help you guys. (KAMiN)
i dont think hte oil is getting into the combustion chamber - just the top of the spark plug hole?
but yah, KAMiN is right,
if you are unsure, take it to a place that is...
t..
Old Jul 7, 2002 | 10:52 PM
CalvitoSol's Avatar
yea, just the top of the spark plug hole. one more question. after a few hard runs, my car has a funny smell, what can that be? thanx
Old Jul 7, 2002 | 10:53 PM
tinkerbell's Avatar
the engine
Old Jul 7, 2002 | 11:47 PM
CalvitoSol's Avatar
is that normal?
tinkerbell's Avatar
is what normal?
Old Jul 7, 2002 | 11:54 PM
tinkerbell's Avatar
sorry, i've had a bad day.
yes it is normal for hte engine to 'smell funny'
if you can tell, sometimes it will smell like heaps of things,
mine after a hard run smells mostly like:
1. coolant hoses
2. cooked engine oil;
3. burnt engine oil;
4. heated aluminium;
5. K&N air filter;
and
6. brake pads.
all these smells are 'normal' after a hard run.
but too much of one means a problem, you jsut need to learn how to read your nose and ears to teh smells and sounds of your ride...
anyways,
HopeTH,
t..
Old Jul 8, 2002 | 12:03 AM
salbaje's Avatar
you did replace o rings but might not be on there properly. double check those. also the funny smell might be hondabond burning due to your motor getting hot?? just a thought
standbackimapro
Apr 29, 2006 05:38 PM
krz6jdm
Apr 7, 2006 06:36 PM
Jeff
Oct 10, 2005 09:54 PM
coupon
Jun 29, 2005 08:56 AM
tlm756
Jul 18, 2004 02:13 PM
