gc extended tophats
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Sumslapper »</TD></TR><TR><TD CLASS="quote">yes</TD></TR></TABLE>
As long as you have the correct diameter bushings in them. Stock is 10mm and Koni are 12mm.
a lot of people run them just up front but if you ride super slammed definately consider them in the rear. I have all four corners and i dont think the rear has ever bottomed out.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by BIG T »</TD></TR><TR><TD CLASS="quote">not to thread jack but are you supposed to get these for the rear as well or just the front</TD></TR></TABLE>
I only run them in the front.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by gabebauman »</TD></TR><TR><TD CLASS="quote">
are you on oem front shocks?
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 4dek »</TD></TR><TR><TD CLASS="quote">
are you on oem front shocks?</TD></TR></TABLE>
Koni Sports
Koni Sports
so extended top hats will allow you to go lower? Cause once i hit a certain height, it starts to squeak really bad. Would these get rid of that propblem?
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by tunerkid7 »</TD></TR><TR><TD CLASS="quote">so extended top hats will allow you to go lower? Cause once i hit a certain height, it starts to squeak really bad. Would these get rid of that propblem?</TD></TR></TABLE>
If the "squeak" is due to bumpstop compression, then yes. If not, then no.
Are you sitting on the bumpstops at ride height now?
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 4dek »</TD></TR><TR><TD CLASS="quote">will the gc extended tophats fit my stock front shocks on my ek?</TD></TR></TABLE>
Why would you run stock shocks with coilovers?
Sounds like you have more important things to spend money on than upper mounts.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by TunerN00b »</TD></TR><TR><TD CLASS="quote">
Are you sitting on the bumpstops at ride height now?</TD></TR></TABLE>
No, so what would that mean
Thanks
Thanks
Thanks</TD></TR></TABLE>
If your suspension squeaks, and you aren't pushing into the bumpstops, then its probably a polyurethane bushing of some form.
My GC extended upper mounts came with polyurethane spring isolators, and my front suspension squeaks on speedbumps and entering/leaving driveways, whenever there is quit a bit of compression, due to the spring twisting against the poly.
int3gra07
Dec 16, 2006 10:08 PM
