b series in a crx questions
so ive read around Alot about doing this swap and i have a complete 90 da that im taking the engine out of. my questions are, ive read that all the wiring is the same sense they are both obd0. is that true? is the stock exhaust manifold the same length as the d? is the speedo the same set up as crx? basically... is there anything i should look out for before i start this, because i have very little time to do this, and i have to get it done quick. ive done swaps and have everything to do this.
if you have done "swaps" then you should already know the answers.........Anyway you need to be ALOT more specifec about what type crx you have. Year? MPFI? DPFI? SI?
Or you could just look in the FAQ. everything i needed to know to do my swap was in there.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 2slow4stock »</TD></TR><TR><TD CLASS="quote">FaQ and search buttom FTW</TD></TR></TABLE>
greasemonky50
51
Mar 14, 2006 01:12 PM
