92 civic hatchback question??
my hatchback makes this wierd noise when i make a right turn or when im just driving straight. when i make a left turn the noise goes away. i think the sound is coming from the front driver side tire. i need help if possible
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by spyderazn »</TD></TR><TR><TD CLASS="quote">my hatchback makes this wierd noise when i make a right turn or when im just driving straight. when i make a left turn the noise goes away. i think the sound is coming from the front driver side tire. i need help if possible</TD></TR></TABLE>
ITS YOUR FLUX CAPACITOR!!! ITS ABOUT TO BLOW, QUICK, BURN THE CAR!
No, but seriously, you have to be a bit more detailed on what type of noise etc.
Grinding/screeching/etc, did it just start one day? or did one day it start doing it only when you were turning, and one day it did it while u were straight as well.
last time I had a noise that was a grinding noise in my Taurus SHO only when I turned a certin way, and then after a while the noise continued even while driving straight it was my wheel bearings (which it most likely is, bring it to a place like farm and fleet that does 'free inspections' ask whats wrong, they tell you, then thank them and leave and do the work yourself)
lift the car up... look from underneath and examine the outer CV boot. The is the rubber boot that surrounds the axle... looks like this
if it is torn or riped it might look like this
This is one of a few things that may make that noise... good luck
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by kmeng »</TD></TR><TR><TD CLASS="quote">hi-im new but i was wondering if anyone knows where i can get some light bulbs for my jdm eg headlights that fit?</TD></TR></TABLE>
Japan?
Japan?
I'm gonna go out on a limb here and say your local Bakery will most likely have the headlight bulbs you are looking for.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Dasfinc »</TD></TR><TR><TD CLASS="quote">
I'm gonna go out on a limb here and say your local Bakery will most likely have the headlight bulbs you are looking for.</TD></TR></TABLE>
x2
i heard they bake the best JDM headlights
x2
