GSR 1/4 time (Fontana speedway march 8th 2008) 12.2 @ 111 mph
Old Mar 9, 2008 | 10:14 AM
vtec_killer_'s Avatar
Default (Updated ) GSR 1/4 time (Fontana speedway march 8th 2008) 12.2 @ 111 mph
well after seeing another thread with a gsr 1/4 mile time i thought i would post mine for opinions.. here is my setup
Gsr long block
blox intake manifold
99 b16 tranny no LSD
t3/t4 drag manifold
t3/t4 turbo 57/63
10 psi boost
305 hp 245 tq
22x8x13 M&H slicks on lenso's
i will let the timeslips speak for themselves...
i know for 1, i need longer gears. 2 need bigger slicks. any other things u guys could think of please help. would like to get to the 11's soon.
Modified by vtec_killer_ at 8:26 PM 4/28/2008
Old Mar 9, 2008 | 11:19 AM
H.Veras's Avatar
Nice times for a simple setup. In my personal opinion I would not do bigger slicks, I would just do longer gears and a little bit more boost. But, great times and it seems like you are a good driver.
Old Mar 9, 2008 | 11:20 AM
HondamanXxX's Avatar
GO GIANTS!
Default Re: (H.Veras)
Some nice 60's
Old Mar 9, 2008 | 11:22 AM
MindLess311's Avatar
Id say just move up to a 24.5 slick what gear and what rpm are you finishing in??
Old Mar 9, 2008 | 12:49 PM
Default Re: (MindLess311)
i shift into 5th gear about 100 ft before finish line. i was told to get 23'' slicks and a gsr tranny i would be straight, but that is why i am getting opinions from HT.
thanks for the
Old Mar 9, 2008 | 12:55 PM
reaction360's Avatar
Default Re: (vtec_killer_)
i'd first do a gsr trans. and then go run it and see how you like it then.
Old Mar 9, 2008 | 01:06 PM
Tippyman's Avatar
Default Re: (reaction360)
You shouldn't change your trans. Drag racing loves short gears. You ideally want to be in the top of fourth right when you cross the line. Shifting to fifth is not good...
Try some bigger slicks. Google search "crx math" for a calculator for gearing.
Old Mar 9, 2008 | 02:41 PM
Dr. D-Series's Avatar
How much does that car weigh ?
111mph with 300 whp sounds a bit low unless the cars a pig.
Old Mar 9, 2008 | 04:24 PM
HamiltonRex's Avatar
Default Re: (Dr. D-Series)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Dr. D-Series &raquo;</TD></TR><TR><TD CLASS="quote">How much does that car weigh ?
111mph with 300 whp sounds a bit low unless the cars a pig.</TD></TR></TABLE>
It sounds fine to me.
Old Mar 9, 2008 | 04:41 PM
Im not saying its bad at all.
I just know that my 202 whp hatch trapped 112.
But its probably a bunch lighter.
Thats why I asked how much it weighs.
That ok ?
Old Mar 9, 2008 | 06:01 PM
i have no idea about the weight, but only thing missing is the carpet and and back seats and the sound deadning. looking at my 60 ft times say's i dont need a different tranny, but at the end of the dragway i would be better off in 4th instead of 5th.
Old Mar 9, 2008 | 06:33 PM
hondaguyef's Avatar
What's the MPH on that first run? I don't see how the car picked up from 104 to 111mph between the last two runs? Anyhow, What RPM are you shifting at? I'd stick with the 22's and the B16 trans. Just run the rpm up a lil' more through the traps and you should be fine. If you plan on making more power in the future then maybe think of running a taller tire.
Phil
Old Mar 9, 2008 | 06:50 PM
Default Re: (hondaguyef)
oh by the way, that first past was @ 108 mph kinda hard to see but thats what it was.
8200 redline
Old Mar 10, 2008 | 02:20 PM
PHDZINE's Avatar
Bump the Rev limiter up so your not shifting into fifth gear at the end.
Old Mar 10, 2008 | 02:24 PM
ExospeedAMcrx's Avatar
john,
the 2 easiest choices to do is either get a 23x8x13 slick or raise the rev limiter like Paul said. you need to be shifting at 9K and you'll be good.
24.5" slicks are way too big for that setup and is not necessary.
Old Mar 10, 2008 | 05:45 PM
KHAN SHOP's Avatar
Default Re: (ExospeedAMcrx)
I give you , cars were running like sh#t out there. Where did you dyno at ?
Old Mar 10, 2008 | 09:28 PM
thanks will and everyone for the response's, yeah i think i am gonna get that 23x8x13 slick and try that.
i think that will be my quik solution for now..
i was dyno'd @ whittfield racing
i do believe my car has a potential to hit ll's, might just take that good driving skills to get there, but eventually i will be there.
i am gonna work on the head now for that rev limiter problem..
Old Mar 11, 2008 | 07:55 AM
SovXietday's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by hondaguyef &raquo;</TD></TR><TR><TD CLASS="quote">What's the MPH on that first run? I don't see how the car picked up from 104 to 111mph between the last two runs? </TD></TR></TABLE>
I'd probably chalk it up to having to shift into 5th. Not easy to do in a fast manner by any means.
If you're not done turning up the boost I'd say go with 24.5s, but if you're happy with the power now just get some 23s and bump up the limiter 500rpms and you'll be peachy.
Old Mar 11, 2008 | 08:36 AM
Honda Bull's Avatar
Default Re: (SovXietday)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by SovXietday &raquo;</TD></TR><TR><TD CLASS="quote">
If you're not done turning up the boost I'd say go with 24.5s, but if you're happy with the power now just get some 23s and bump up the limiter 500rpms and you'll be peachy. </TD></TR></TABLE>
Ditto.
Old Mar 11, 2008 | 02:55 PM
Why is shifting to 5th so hard ?
I find it just as easy as any gear.
FTS 5th tons of times.
Old Mar 11, 2008 | 03:54 PM
PHDZINE's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Dr. D-Series &raquo;</TD></TR><TR><TD CLASS="quote">Why is shifting to 5th so hard ?
FTS 5th tons of times.</TD></TR></TABLE>
Nobody said it was hard...why would you want to shift to 5th if you can finish in 4th?
Old Mar 11, 2008 | 04:28 PM
Dont get me wrong I agree with you. Id also rather cruise through in 4th.
But if your going down the track and you need to go 5th, might as well bang in.
Old Mar 11, 2008 | 07:20 PM
SovXietday's Avatar
Default Re: (Honda Bull)
I'm a pro now that I own my Camaro. 2-5 shifts FTW!
Still, considering the power is there, less shifts = faster. But we all know this.
Old Mar 11, 2008 | 07:42 PM
shifting into 5th was kinda crazy for the first time. But i had to cause the 12.7 and the 12.9 was ending in 4th gear pinging that rev limiter. So i think the fella's are right about moving that shifting point up about 500 to 1000. I just bought these 22x8x13 and now i have to sell them to get faster. but i love my lenso's, they are freakin so light, mucho compliments to these rims. I say i had a good day at the track, only downfall was that the slicks rubbed on my left front brake line and leaked fluid all over the place. i had to use my e-brake just to get home...LMAO... well anyways problem already fixed.. can't wait till we hit the track again..
Old Mar 12, 2008 | 10:17 AM
KHAN SHOP's Avatar
More pics of the car and engine bay? I just wanna know what car it is when I am at the next street drags
