Honda Civic (2006 - 2015) 2006 - 2015 Civic Forums
Stock 07 Si Coupe Get Header??
Old Mar 9, 2008 | 05:54 AM
riptide's Avatar
Default Stock 07 Si Coupe Get Header??
I am deciding whether to get the Vibrant race header with high flow cat, and then I would reflash w/ hondata...just wondering , still, if it is worth the trouble....
Old Mar 9, 2008 | 07:22 AM
RICO_'s Avatar
NO MERCY!
Default Re: Stock 07 Si Coupe Get Header?? (riptide)
Go for it. You'll see some pretty good gains both top-end from the RH and mid-range from the reflash.
Old Mar 9, 2008 | 09:04 AM
splinter888's Avatar
Default Re: Stock 07 Si Coupe Get Header?? (RICO_)
Definitely worth it youll see some pretty decent gains especially from the reflash. K's respond well to mods good luck to you sir
Old Mar 9, 2008 | 09:54 AM
07siftw's Avatar
Default Re: Stock 07 Si Coupe Get Header?? (splinter888)
make sure you want the reflash man because when your racing (shifting at redline) you will see minimal gains from hondata. Wait till k-pro comes out. However, get all the bolt-ons you can.
Old Mar 9, 2008 | 11:48 AM
reaper702's Avatar
Default Re: Stock 07 Si Coupe Get Header?? (07siftw)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 07siftw &raquo;</TD></TR><TR><TD CLASS="quote">make sure you want the reflash man because when your racing (shifting at redline) you will see minimal gains from hondata. Wait till k-pro comes out. However, get all the bolt-ons you can.</TD></TR></TABLE>
An Si with I/H/E + Reflash will beat the car with I/H/E and no reflash in the 1/4 mile, wtf are you talking about? With the reflash, it brings the vtec engagement much quicker + you can rev to 8600rpm which means a larger average of power over the stock ecu car. On a DD, it is a completely different car around the city as you get more power in the midrange, which is more important in DD.
If you buy the reflash, hondata usually gives you $500 credit towards the standalone engine management (will NOT be k-pro for the k20z3), so no reason to buy. Great mod, worth every penny imo
Boosted_Rex.
Nov 28, 2007 10:04 AM
94IntegraLs04
Mar 30, 2006 03:50 PM
jorgie583
Honda S2000
13
Nov 1, 2005 07:40 AM
FastAllmotorLsVtec
20
Apr 6, 2004 12:22 PM
VTECdTypS
Dec 29, 2003 08:35 PM
