NRG Thin QR is frustrating me right now.
Old Mar 8, 2008 | 10:22 PM
Dilly's Avatar
Default NRG Thin QR is frustrating me right now.
ok... how the HELL do you detach the NRG Thin QR?!?!?!?
i've tried to find FAQ on forums/google.
i couldn't find any instructions on how to use it.
my common sense is, you press the button, and twist..... right?
not workin for me.
help please!
Old Mar 8, 2008 | 10:23 PM
caustic.'s Avatar
mike lawry
Someone help Dilly, quick.
Old Mar 8, 2008 | 10:28 PM
Dilly's Avatar
Default Re: (caustic.)
thanks man.
help!
bump.
Old Mar 8, 2008 | 10:29 PM
Ep1dem1c's Avatar
The piece that says open/close... turn that i think thats how you do it
Old Mar 8, 2008 | 10:33 PM
Dilly's Avatar
Default Re: (Ep1dem1c)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Ep1dem1c &raquo;</TD></TR><TR><TD CLASS="quote">The piece that says open/close... turn that i think thats how you do it</TD></TR></TABLE>
i've tried everything that i could. ended up with nothing.
Old Mar 8, 2008 | 10:35 PM
Ep1dem1c's Avatar
Default Re: (diLLy)
maybe it is broke
Old Mar 8, 2008 | 10:36 PM
Dilly's Avatar
i'll be pissed.
hahaa.
but brand new.
i can feel it move and click, but it wont twist off.
Old Mar 8, 2008 | 10:44 PM
Ep1dem1c's Avatar
Default Re: (diLLy)
maybe you need more leverage.. like if it was on the car and then press the button and turn?
Old Mar 8, 2008 | 10:46 PM
Dilly's Avatar
i tried sticking two metal rods in there to get leverage and i had my brother hold it while i turn the wheel, but nothing.
Old Mar 8, 2008 | 10:56 PM
asiandoood's Avatar
it is easier when you have it mounted. The release is based off the FET design.
push the button, twist the base (gray piece in pic 1...pull the steering side .
Old Mar 8, 2008 | 11:02 PM
Dilly's Avatar
Default Re: (asiandoood)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by asiandoood &raquo;</TD></TR><TR><TD CLASS="quote">it is easier when you have it mounted. The release is based off the FET design.
push the button, twist the base (gray piece in pic 1...pull the steering side . </TD></TR></TABLE>
the thing is.... i cannot mount the momo hub to the quick release without detaching the quick release.
reason why i need to detach it now is so i can attach the hub to the release.
Old Mar 9, 2008 | 09:34 AM
.wtf's Avatar
Default Re: (diLLy)
lmao......... !
Old Mar 9, 2008 | 09:52 AM
what gsr's Avatar
Default Re: (.wtf)
haha this is funny sorry... but scary too because i just bought one!
hope you figure it out dude!
Old Mar 9, 2008 | 09:54 AM
asiandoood's Avatar
Default Re: (diLLy)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by diLLy &raquo;</TD></TR><TR><TD CLASS="quote">
reason why i need to detach it now is so i can attach the hub to the release.</TD></TR></TABLE>
if going by picture 2, push the release button, turn the base clockwise while turning the steering wheel counter clockwise and pull steering wheel off. it is not that difficult.
Old Mar 9, 2008 | 10:15 AM
WhiteSlips's Avatar
I say take it off and replace it with a regular quick release. Those things have play and are garbage as far as I'm concerned. Good luck with it either way though.....
Old Mar 9, 2008 | 10:23 AM
29psiHybrid's Avatar
Default Re: (WhiteSlipsWithStickers)
Your steering wheel bolts might be too long, I ran into this with mine. Loosen them up a little and see if it unlocks...
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by WhiteSlipsWithStickers &raquo;</TD></TR><TR><TD CLASS="quote">I say take it off and replace it with a regular quick release. Those things have play and are garbage as far as I'm concerned. Good luck with it either way though.....</TD></TR></TABLE>
Mine had play in it too, even before it cracked and became a $80 paperweight
Old Mar 9, 2008 | 09:51 PM
Dilly's Avatar
Default Re: (29psiHybrid)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 29psiHybrid &raquo;</TD></TR><TR><TD CLASS="quote">Your steering wheel bolts might be too long, I ran into this with mine. Loosen them up a little and see if it unlocks...
i did as you said but nothing. it DOES NOT want to turn AT ALL.
if going by picture 2, push the release button, turn the base clockwise while turning the steering wheel counter clockwise and pull steering wheel off. it is not that difficult. </TD></TR></TABLE>
i understand that, common sense right? but its NOT budging.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by proper! &raquo;</TD></TR><TR><TD CLASS="quote">haha this is funny sorry... but scary too because i just bought one!
hope you figure it out dude! </TD></TR></TABLE>
did you get yours yet? let me know if you were able to detach it.
Old Mar 9, 2008 | 09:56 PM
B2FiNiTY's Avatar
Default Re: (diLLy)
sounds broken. return it. DONE.
Old Mar 9, 2008 | 10:00 PM
UCLA.lion's Avatar
I <3 My CB7.
Default Re: (B2FiNiTY)
gen 2 for life
Old Mar 9, 2008 | 10:13 PM
Dilly's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by B2FiNiTY &raquo;</TD></TR><TR><TD CLASS="quote">sounds broken. return it. DONE.</TD></TR></TABLE>
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by UCLA.lion &raquo;</TD></TR><TR><TD CLASS="quote">gen 2 for life</TD></TR></TABLE>
i want a thin QR though.
Old Mar 9, 2008 | 10:18 PM
foam's Avatar
hey perfect timing. How does the Thin QR compare with a Slim Hub? Is it closer to OEM? or Really close to the dash?
Old Mar 9, 2008 | 10:26 PM
Sean @ ESG's Avatar
FET &gt; NRG ****
Old Mar 9, 2008 | 11:02 PM
Dilly's Avatar
Default Re: (foam)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by foam &raquo;</TD></TR><TR><TD CLASS="quote">hey perfect timing. How does the Thin QR compare with a Slim Hub? Is it closer to OEM? or Really close to the dash?</TD></TR></TABLE>
i dunno how it compares to the slim hub.
ahaha.
sorry.
i just got a momo hub with it.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Sean @ ESG &raquo;</TD></TR><TR><TD CLASS="quote">FET &gt; NRG ****</TD></TR></TABLE>
well of course, but FET is discontinued and i couldnt find any.
so i messed around with the QR for a little bit. where the button is, theres an allen screw. i loosened that and the button along with a spring shot out. after that happened, i was able to detach the fu*king QR. now after evaluating the button, i found that the button and spring were fu*king useless. it did nothing but blocked the QR from detaching. so uh... yeah....
Old Mar 9, 2008 | 11:13 PM
Dilly's Avatar
Default Re: (diLLy)
ok!
so i messed with it even more, and FINALLY got it to work. it seemed to me like the button had a slight failure before i unscrewed the allen screw. now it works....
thanks to those who helped.
also, its my birthday today.
march 10.
yay me.
hahaa.
Old Mar 10, 2008 | 03:26 PM
asiandoood's Avatar
Default Re: (Sean @ ESG)
FET has discontinued both their version 1 and 2 b/c it failed and fell apart.
