97 accord wheel & tire size
Old Mar 8, 2008 | 08:18 PM
WillEat4F00d's Avatar
Default 97 accord wheel & tire size
I have a 97 Accord. The "recommended" specs for the tires are: 185 65R 15 88S. If I wanted to get 17 or 18 inches instead, what kind of specs would I have to look for? Thx.
Old Mar 9, 2008 | 09:39 AM
nsxtasy's Avatar
H-T Order of Merit
Default Re: 97 accord wheel & tire size (WillEat4F00d)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by WillEat4F00d &raquo;</TD></TR><TR><TD CLASS="quote">I have a 97 Accord. The "recommended" specs for the tires are: 185 65R 15 88S.</TD></TR></TABLE>
That's often referred to as 185/65-15, which is the old way that tire sizes were expressed. The other specs aren't all that important when selecting a tire. The R in the middle doesn't mean anything important; it just means that it's a radial tire, which most quality tires are. The 88 is a load rating and the S is a speed rating; as long as you're buying good-quality tires, the load and speed rating are extremely likely to meet the minimum needs of your car.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by WillEat4F00d &raquo;</TD></TR><TR><TD CLASS="quote">If I wanted to get 17 or 18 inches instead, what kind of specs would I have to look for?</TD></TR></TABLE>
205/45-17 for the 17", 215/40-18 for the 18". I recommend not going larger than 17", though; the short sidewalls on the 18" leave the wheels susceptible to damage from potholes.
If you're looking for good tires in 205/45-17, I recommend one of these:
<u>If you never will use them on snow or in frigid cold:</u>
Dunlop SP Sport Maxx $130
Kumho Ecsta SPT $97
Yokohama ES100 $99
Yokohama S.drive $107
<u>If you need to use them on snow and in frigid cold as well as in moderate to warm temperatures:</u>
Avon Tech M550 A/S $99
Above prices are from the Tire Rack.
Old Mar 9, 2008 | 09:42 AM
Thanks. Yeah, I was planning to get 17's anyways because 18's looked too big for the car. I will be looking for those first set of tires you posted since I live in the deep south and it never snows or anything.
teenagersmom
Apr 10, 2015 04:22 AM
sexyIMPORTchic
Nov 8, 2010 09:10 AM
thakidd
Apr 9, 2008 01:57 PM
thakidd
Jan 24, 2008 01:20 PM
professorman
Jan 17, 2005 06:37 AM
