Stereo wont turn on!!!!!
I bought my 92 Prelude with no stereo and when I went to plug in my stock oem honda stereo it wouldnt turn on. I know the stereo is good because i just pulled it from my other lude a couple of days ago. I also don't get light in the climate control. Anyone?
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by dre2day »</TD></TR><TR><TD CLASS="quote">Don't forget you might need the code to turn the raido on</TD></TR></TABLE>
The radio will turn on with out the code. You will know it has power. With out the code it wont play music, but it will light up.
Well I have taken off this particular stere off a couple of times and it does not throw any codes. It works fine in my other lude so I know its not the stereo. What size fuse would I need to replace it?
open your fuse box, look at the diagram on it. look for the radio fuse, see if it is there or if it is blown, and replace it if it is missing or blown. the diagrams usually even say what size fuse you need.
ok if the stereo is not turning on then that means that someone has tried to enter the code if it is off and not turining on then you will need to leave your car on for 8 streight hours so it can reboot itself that happen to me and and the 8 hours did the job....good luck
kingh90 <TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote »</TD></TR><TR><TD CLASS="quote"> "ok if the stereo is not turning on then that means that someone has tried to enter the code if it is off and not turining on then you will need to leave your car on for 8 streight hours so it can reboot itself that happen to me and and the 8 hours did the job....good luck". </TD></TR></TABLE>
W..T....f?
W..T....f?
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Mr.Lude »</TD></TR><TR><TD CLASS="quote">kingh90
W..T....f?
</TD></TR></TABLE><TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by dre2day »</TD></TR><TR><TD CLASS="quote">I've never heard of this technique, where did you get this information?</TD></TR></TABLE>
He is right, if you enter the code on the stero wrong three times in a row, the stero will shut itself off and you have to try again 8 hours later.
W..T....f?
</TD></TR></TABLE><TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by dre2day »</TD></TR><TR><TD CLASS="quote">I've never heard of this technique, where did you get this information?</TD></TR></TABLE>He is right, if you enter the code on the stero wrong three times in a row, the stero will shut itself off and you have to try again 8 hours later.
bro im telling you..this happen to my prelude and i took it back to the honda dealer and they told me that i had entered the code wrong 3x and the told me to leave it running for 8 hours so it can reboot it self. and it did its not a joke...or just contact you nearest honda dealer and take it in..they might be able to help you
Rip the harness out of the car and plug it into the back of the radio. Carefully, tie the negative wire to negative terminal, and put the power and Acc wi
**** just take it to Honda and ask them to test it for you. There is afuse on the back of stero that may be blown. If no fues are blown and the stero is fine, its time to run new wires
