98 ECM work in a 97??? need help/answer ASAP!
Old Mar 8, 2008 | 02:41 PM
nuke1979's Avatar
Default 98 ECM work in a 97??? need help/answer ASAP!
I'm needing a 1997 Base 5pd Enigne computer. I've found a few but only for a 98 base 5sp. I called a Honda dealership and talked with a few techs. They said that only a 97 computer will work. not a 98. They said there is a few different sensors between the 97 and 98. From my understanding I thought it would.
Wanted to triple check here, any replies will be appreciated.
Old Mar 9, 2008 | 12:27 PM
slamdlude's Avatar
Default Re: 98 ECM work in a 97??? need help/answer ASAP! (nuke1979)
I know that all 97+ preludes have an immobilizer system and the ecu will have to be reflashed and a new red key programmed no matter what factory ecu you put in it. Then you can reprogram any keys you already have. Unless the ecu comes with keys and you want to rekey your car to those keys. Other than that I do not know if a 98 ecu will work in a 97.
Old Mar 9, 2008 | 12:30 PM
vinuneuro's Avatar
98+ emissions are different from 97. You need to find a 97 ecu.
Old Mar 9, 2008 | 05:49 PM
BeyondTheCompetition's Avatar
Default Re: 98 ECM work in a 97??? need help/answer ASAP! (vinuneuro)
What about and 98 motor in a 97 Lude with a 97 ECU? uhoh Haven't tried to start it yet after the engine install yesterday...willI encounter a million problems?
Old Mar 9, 2008 | 07:14 PM
vinuneuro's Avatar
Default Re: 98 ECM work in a 97??? need help/answer ASAP! (BeyondTheCompetition)
Is the evap system still the same? I doubt you swapped that out with the motor.
Old Mar 10, 2008 | 07:01 AM
Rob97'SH's Avatar
I have a 97 SH ecu if that will work.
Thibis
Jul 31, 2014 04:15 AM
typer1982
Jun 21, 2007 11:09 PM
sixfiveoh
May 23, 2006 11:23 PM
Mr.Fairlady
May 27, 2002 07:48 PM
