help
Old Mar 8, 2008 | 12:45 PM
meric0786's Avatar
Default help
was woundering if the spindals on an eg are the same as the ones on the integras and what is the spline count
Old Mar 9, 2008 | 11:24 AM
ctr83's Avatar
Default Re: help (meric0786)
yes they are the same. that's why you can use integras axles in civics.
Old Mar 9, 2008 | 11:48 AM
NJIN BUILDR's Avatar
The inside diameter and splines are the same,the axles will swap.There are two hub/wheel bearing size on eg's.The abs cars have a larger od hub and wheel bearing than the non-abs.
PreludeJunkie91
Jul 7, 2018 02:13 PM
alex1320
Mar 6, 2013 08:47 AM
Cynical 1
Suspension & Brakes
Jan 17, 2011 06:00 PM
