205 or 225 BFG drag radials...
All motor setup, 208 whp, full interior DC4, would u recommend 205 or 225/50/15 drag radials, these are gonna be mounted probably on crappy rotas, and this is just for the 1/4 mile track
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by mike93eh2 »</TD></TR><TR><TD CLASS="quote">geez what offset is that? mine dont look like that.</TD></TR></TABLE>
the rims are 15x8 with i belive a +25 offset 75mm lip and the tires are 225/50/15 in the front and 205/50/15 in the rear.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by DOHc SIdE »</TD></TR><TR><TD CLASS="quote">what tranny cause the 225 maybe to tall of a tire id say 205</TD></TR></TABLE>
I was wondering the same thing.
98+ JDM ITR... 4.7 FD
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by racin jasin R »</TD></TR><TR><TD CLASS="quote">they are no good,so dont buy them
real men run slicks..</TD></TR></TABLE>
x2
x2
i hear guys gettin good 60' times with these, thats why im wondering, maybe ill just end up gettin slicks, but j.w. which is better between the 2 205 or 225
I am pretty sure 225 is the width of the tire, not the height, so the only difference between the 2 sizes is surface area obviously the 225 has more area contacting the ground.... If you can fit them, get the 225. But if its only for track i would say slicks hands down. the best feeling when they hook up
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Dat1BVtecN »</TD></TR><TR><TD CLASS="quote">
i hear guys gettin good 60' times with these, thats why im wondering, maybe ill just end up gettin slicks, but j.w. which is better between the 2 205 or 225</TD></TR></TABLE>
not bfg.. MT's
not bfg.. MT's
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ICeDoUt »</TD></TR><TR><TD CLASS="quote">
no, the 225 doesnt exactly mean the width.
the wider the tire goes it also gets taller.
a 225/50/15 is 0.8 inches taller than a 205/50/15
</TD></TR></TABLE>no, the 225 doesnt exactly mean the width.
i heard of guys getting good 60 foots w/ slicks.
My room mate just got some 225's on a 4.4 f/d. Thats what you will want if you insist on buying them
The "50" in the 225-50-15 means the side wall of the tire is 50% of the width of the tire (225mm)
. A 225-50-15 will always be taller than a 205-50-15.
225
I must say I used to switch between MT Slicks and the Radials. Slicks were def easier to launch on.
These tires get STICKY, I broke an axle using these tires and not slicks
