Suspension & Brakes Theory, alignment, spring rates....
question with installing poly bushings in front lcas
Old Mar 8, 2008 | 11:19 AM
atleast-3's Avatar
Default question with installing poly bushings in front lcas
i just want to know if these just press in? you just press in from one side like you would an oem bushing?
Old Mar 8, 2008 | 12:29 PM
PIC Performance's Avatar
Default Re: question with installing poly bushings in front lcas (atleast-3)
What car?
Old Mar 8, 2008 | 12:49 PM
atleast-3's Avatar
Default Re: question with installing poly bushings in front lcas (PIC Performance)
95 civic ex
Old Mar 8, 2008 | 01:09 PM
YELLOW_DUCK's Avatar
press out or burn the bushing out, then saws all the ring out.
then press in using a press or a bench vice
use lots of lub
Old Mar 8, 2008 | 01:20 PM
atleast-3's Avatar
Default Re: (YELLOW_DUCK)
got one more question, that lube that ES gives, is it just me or does that stuff not work really well at all. i pressed in my shifter linkage bushings, and all it really seemed to do was make a sticky mess, is there a better product to use when pressing in PU bushings?
Old Mar 8, 2008 | 01:26 PM
Default Re: (atleast-3)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by atleast-3 &raquo;</TD></TR><TR><TD CLASS="quote">got one more question, that lube that ES gives, is it just me or does that stuff not work really well at all. i pressed in my shifter linkage bushings, and all it really seemed to do was make a sticky mess, is there a better product to use when pressing in PU bushings?</TD></TR></TABLE>
yes it makes an awesome sticky mess, but you need to use that stuff excessively. gob that $hit on, and make sure to use anti-seez on everything, meening the bolts. if you dont have it, go get some.
Old Mar 8, 2008 | 01:31 PM
atleast-3's Avatar
ok, thanks for the info, if you got any others tips or tricks im all ears.
Old Mar 8, 2008 | 03:24 PM
have a saws-all in hand w/ a metal blade incase you have to cut um out and extra bolts and nuts. i used grade 8 bolts. have fun
hillbillycivic
Mar 13, 2013 08:14 PM
vlc92189
Oct 4, 2007 10:40 AM
sageuvagony
35
Jun 24, 2007 02:00 PM
len
May 2, 2003 11:26 PM
ahead
Jan 30, 2003 06:41 PM
