89 si electrical help
Old Mar 8, 2008 | 10:39 AM
mrflak0's Avatar
Default 89 si electrical help
im stumped, i have a 89 hatch si itt has a z6 in and everything was running fine, drove home from work one day and i get a random miss fire then it starts miss firing so i pull over and cut it off, i start it back up no problem when i get it home it starts fine revs fine, but if i turn on the lights it will hold idle for a second then itll kill the motor, it does the same thing when i put on the rear defroster. the tank is full but it reads empty does anybody know if the lights r defroster and fuel pump share a common ground or if the wires for these things run together in the same part of the engine or chassis harness. any imput would be apriciated
Old Mar 8, 2008 | 11:26 AM
Former User's Avatar
Default Re: 89 si electrical help (mrflak0)
1) **Check whether the alternator is failing.
2) Also check whether the battery charge is low, as well as whether the battery connectors are corroded or loose.
Old Mar 11, 2008 | 11:46 PM
mrflak0's Avatar
Default Re: 89 si electrical help (RonJ@HT)
thanks for the help
tommikaira
Jul 17, 2009 11:39 PM
trianglegreg
May 15, 2008 12:23 PM
x91crxsix
Dec 6, 2006 09:40 AM
90YellowRex
Jan 22, 2006 08:35 PM
djsire
Nov 9, 2005 02:21 PM
