What Clutch should i Use ......I have a ZC Motor single Cam Motor, Help???
Old Mar 7, 2008 | 09:55 PM
94EJ1Coupe's Avatar
Default What Clutch should i Use ......I have a ZC Motor single Cam Motor, Help???
I have a 88 Crx HF with a ZC swap. I need a new Clutch and wanted to know how to search for the right fit for my Motor. It's a little hard since It's a ZC which I think is equivalent to a 1.6 or 1.5 D series Motor. Not sure????? ( help Please), do i need 21 splines or 20? and under what motor or CRX/Civic should i Place the order? thinking about buying it on EBAY. HELPPPP Please!!!!!!!!
Old Mar 7, 2008 | 10:12 PM
whiteknightef's Avatar
Default Re: What Clutch should i Use ......I have a ZC Motor single Cam Motor, Help??? (dj Just Right)
A zc motor is a d16a6 equivilent motor. The d16a6 came in the 88-91 si or the 88-91 ex civics and crx's. You will do best to order clutch for your 88 civic and then use the flywheel off your old engine. If that is not possible then you'll have to count the splines on the input shaft and find out what clutch correlated with that spline count. Also there were two sizes of flywheels made, so do some searching to find out. Napa, or Autozone, or any parts store can tell you easily. I have a bad memory so I can't ever remember what the exact info is.
Old Mar 7, 2008 | 10:19 PM
94EJ1Coupe's Avatar
Thanks for the info!
poofgone
Dec 8, 2007 06:39 PM
DiPPeD iN miLk Ej CoUpE
Jun 15, 2003 11:06 PM
