civic ground control? which one for front and back.
Old Mar 7, 2008 | 08:21 PM
lilo_goki's Avatar
Default civic ground control? which one for front and back.
i have a set of ground control i bought used. don't knoe which one goes in the front and which one in the back. these are what the springs say.
1)GC180.64.44
2)GC200.64.58
which one goes in the front and which one in the rear?
Old Mar 7, 2008 | 11:17 PM
cherroneballs's Avatar
the springs that are real close together at the top are the rears and the ones that are spaced further apart at the top are the fronts.
Old Mar 8, 2008 | 03:56 PM
lilo_goki's Avatar
they all look the same except that one is 8" and the other one is 7".
Old Mar 8, 2008 | 05:26 PM
B serious's Avatar
Cool Cool Island Breezes. BOY-EE
Default Re: (lilo_goki)
the 7'' one should go in the back. What are the spring rates on each? It should say it on there, IIRC.
Old Mar 8, 2008 | 08:05 PM
lilo_goki's Avatar
kewl, so the shorter one should go in the back. i have no idea where it says spring rates. this is all it says
frop top to bottom:
Ground control
Eibach 148031
GC180.64.44
other one:
Ground control
Eibach 162886
GC200.64.58
Old Mar 9, 2008 | 01:52 AM
B serious's Avatar
call the GC customer service line. Talk to a tech.
Old Mar 9, 2008 | 05:50 AM
CerealWars's Avatar
It doest matter what spring goes in front or back, but typically 8" in front 7" in back. What really matters is that you get the numbers converted so you can understand what you have. So here we go.
180.64.44 is 700.250.250
200.64.58 is 800.250.330
Now your probably going to ask what the new numbers mean. First number is length in inches of the springs. Second number is inside diameter in inches and the last number is the spring rate.
Old Mar 9, 2008 | 06:17 AM
mikeycivic's Avatar
Default Re: (CerealWars)
shorter spring in the back
Old Mar 9, 2008 | 09:44 AM
lilo_goki's Avatar
this reallie helps, so softer spring rates in the back and stiffer in the front.
Old Mar 9, 2008 | 10:06 AM
GSR CRX's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by lilo_goki &raquo;</TD></TR><TR><TD CLASS="quote">this reallie helps, so softer spring rates in the back and stiffer in the front.</TD></TR></TABLE>
i would say that it doesnt matter. it is how you want your car to handle.
Old Mar 9, 2008 | 10:26 AM
allshownogo's Avatar
good info
Old Mar 9, 2008 | 10:43 AM
mikeycivic's Avatar
Default Re: (GSR CRX)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by GSR CRX &raquo;</TD></TR><TR><TD CLASS="quote">
i would say that it doesnt matter. it is how you want your car to handle.</TD></TR></TABLE>
It does matter. Your not going to put a softer/shorter spring in the front. You need a stiffer spring to make up the difference for the weight of the motor.
Old Mar 9, 2008 | 10:47 AM
B serious's Avatar
Default Re: (mikeycivic)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by mikeycivic &raquo;</TD></TR><TR><TD CLASS="quote">
It does matter. Your not going to put a softer/shorter spring in the front. You need a stiffer spring to make up the difference for the weight of the motor.</TD></TR></TABLE>
Not really. You can put a stiffer spring in the back. It's done all the time to make the car handle in a certain way. That's the way I roll. Err...rolled. I dont have the car anymore lol.
The only thing is that the spring is shorter. But if you raised up the front perch more, you'd be fine. They're probably MEANT to go 8'' (330lb/in) front and 7''(250 lb/in) rear, though. That's probably how they were sold.
Old Mar 9, 2008 | 10:50 AM
mikeycivic's Avatar
Default Re: (B serious)
yeh you dont NEED to per say but if he's looking for the "standard" way, then shorter spring in the back
Old Mar 9, 2008 | 11:37 AM
johnmay19's Avatar
It does matter front to back. I installed a set with the front's in the rear etc.. I had to really crank the front and lower the back to try and balance them out. I swapped them back and the rears sagged from being up front for a short time.
Old Mar 9, 2008 | 11:38 AM
mikeycivic's Avatar
Default Re: (johnmay19)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by johnmay19 &raquo;</TD></TR><TR><TD CLASS="quote">It does matter front to back. I installed a set with the front's in the rear etc.. I had to really crank the front and lower the back to try and balance them out. I swapped them back and the rears sagged from being up front for a short time.</TD></TR></TABLE>
Old Mar 10, 2008 | 10:16 AM
lilo_goki's Avatar
it feels better having the back softer and having the front stiffer.
Cole D
Suspension & Brakes
10
Jul 10, 2007 07:05 AM
ExospeedAMcrx
Suspension & Brakes
Feb 15, 2007 11:07 PM
cbmprelude
Suspension & Brakes
Jun 5, 2006 09:39 AM
shawn_crx
Mar 9, 2005 03:32 PM
silentkill03
Oct 26, 2004 02:49 PM
