question about putting a si trans in a dx
Old Mar 7, 2008 | 07:43 PM
Zawacki's Avatar
Default question about putting a si trans in a dx
when you put a si trans in a dx the axles are the same right?
Old Mar 7, 2008 | 07:47 PM
B18C5-EH2's Avatar
Former Moderator
Loved
Default Re: question about putting a si trans in a dx (Zawacki)
Yes as long as it really is a DX, and NOT a STD model with the 4 speed tranny. People make the common mistake of calling the STD model "DX" when they're not.
Old Mar 7, 2008 | 10:58 PM
hailchristian's Avatar
Default Re: question about putting a si trans in a dx (B18C5-EH2)
and if it is a std...the std axles will still work with the si tranny
they're just hella weak sause
Old Mar 8, 2008 | 04:50 AM
SirRevvs's Avatar
Default Re: question about putting a si trans in a dx (hailchristian)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by hailchristian &raquo;</TD></TR><TR><TD CLASS="quote">and if it is a std...the std axles will still work with the si tranny
they're just hella weak sause </TD></TR></TABLE>
Correct, axle input cv joints are the same for all d series but on std models the hubs have a smaller outer cv shaft that fits through the hub. But yeas the trannies are the same deal on the outside.
Old Mar 8, 2008 | 07:45 AM
Zawacki's Avatar
so on my girlfriends std modle hatch i have to change the hubs in order to put a dx trans in it?
Old Mar 8, 2008 | 01:38 PM
2slow4stock's Avatar
In your signature It says your g/f has a DX hatch... One question... Is the car 4 speed or 5 speed. It get that out of the way.
Yes you would have to change the hubs also axles. (correct me if im wrong.) (If it is a std model that is)
Old Mar 8, 2008 | 02:08 PM
STREETWERKZ's Avatar
Default Re: (2slow4stock)
NO NEED TO CHANGE THE HUBS OR AXLES.
ON THE STD MODEL, YOU CAN SWAP THE SI TRANS IN USING YOUR EXISTING AXLES.
THE INNERS ARE ALL THE SAME SIZE.
Old Mar 8, 2008 | 04:56 PM
Zawacki's Avatar
her car is a std model 4 speed i have a 5 speed dx trans for it do i need to change the hubs and the axles to use a 5 speed trans on her car?
Old Mar 8, 2008 | 05:05 PM
Loaded Butane's Avatar
Default Re: (STREETWERKZ)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by STREETWERKZ &raquo;</TD></TR><TR><TD CLASS="quote">NO NEED TO CHANGE THE HUBS OR AXLES.
THE INNERS ARE ALL THE SAME SIZE. </TD></TR></TABLE>
No, I guess not. Direct swap in. Never had an std model before. But just swap it in. I was probably mistaken or thinking of the crx HF my bad .
Old Mar 8, 2008 | 05:16 PM
Hamstr323's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by B18C5-EH2 &raquo;</TD></TR><TR><TD CLASS="quote">Yes as long as it really is a DX, and NOT a STD model with the 4 speed tranny. People make the common mistake of calling the STD model "DX" when they're not.</TD></TR></TABLE>
Old Mar 8, 2008 | 05:23 PM
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Zawacki &raquo;</TD></TR><TR><TD CLASS="quote">her car is a std model 4 speed i have a 5 speed dx trans for it do i need to change the hubs and the axles to use a 5 speed trans on her car?</TD></TR></TABLE>
no. the 4spd axles will fit into the 5 speed trans. when you upgrade the brakes, you'll need to change the axles to match.
again, the inners are the same, the outers are whats different.
Old Mar 8, 2008 | 08:44 PM
B18C5-EH2's Avatar
Former Moderator
Loved
I'm not sure why someone gave me the hammer icon.
HIS QUESTION WAS ARE THE AXLES THE SAME, NOT WILL STD AXLES WORK WITH AN SI TRANNY
I simply answered his question in that DX axles are the same as Si axles.
I know the inners are the same, and that the outers are different - I owned a 1990 STD hatch that I did MPFI, Zc/Si hybrid trans, etc.
I guess I should have been a bit clearer but for what he needed my post answered his question if the axles were the same or not. I didn't mean to make it look like STD axles won't work with an Si tranny.
He may have needed to replace an axle or both while swapping trannies, so in that respect my post would be much more helpful than "all EF axles will work with an Si tranny swap."
90civilac
14
Feb 9, 2005 03:03 PM
^Sammy]!.
Aug 13, 2003 06:24 AM
91hondacrx
Dec 15, 2002 07:58 PM
shortyz
Aug 13, 2002 11:48 AM
zcivicz
30
Apr 15, 2002 02:29 PM
