need some all motor transmission advice...
Old Mar 7, 2008 | 06:55 PM
killerpenguin21's Avatar
Default need some all motor transmission advice...
so im trying to finalize my setup for my transmission to go with my 12:1 ls/vtec with pro1's (so say about 200whp)
ive got the lsd and am 99% sure im gonna go with a 4.928 final.
but im undecided if i want to go with mfactory's new first gear.
i have a gsr trans, so the first gear is something like 3.2 stock, the mfactory piece is 3.070, so in my thinking this makes a longer first gear and moves the revs closer to second gear correct? in effect making a pseudo close ratio 1-2? (there close ratio gear set uses a stock 2nd anyway).
look here and tell me what you think
stock vs. 3.070 final
http://www.fatboyraceworks.com...are=1
stock vs. 4.928 final
stock vs. 3.070 +4.928 final
4.928 alone vs. 3.070 first +4.928
Old Mar 7, 2008 | 07:21 PM
UncleD's Avatar
Default Re: need some all motor transmission advice... (killerpenguin21)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by killerpenguin21 &raquo;</TD></TR><TR><TD CLASS="quote"> so in my thinking this makes a longer first gear and moves the revs closer to second gear correct? in effect making a pseudo close ratio 1-2? (there close ratio gear set uses a stock 2nd anyway).
You are correct.
Old Mar 7, 2008 | 07:27 PM
Default Re: need some all motor transmission advice... (clean rice)
so how close does it make it? i havent found anyone with experience yet.
Old Mar 7, 2008 | 07:31 PM
UncleD's Avatar
Time for Bense to chime in for that one
Old Mar 7, 2008 | 08:47 PM
at this point, since i have a deadline by which to get this trans together, and the fact that i need axle seals and new diff bearings i may hold off till next season on the first gear...
the 4.9 should make a pretty big improvement on its own i would think right?
Old Mar 7, 2008 | 10:58 PM
MFactory's Avatar
It really depends on your application. If your car is purely for drag racing, or you do a lot of standing starts at the track, then you will benefit from a longer 1st gear.
However, if it is mainly a daily driver, then it is not a necessity
Changing to the 4.928 is very noticeable in itself.
Seeing as you were thinking of the Final Drive + 1st Gear, have you thought about using our Close Ratio Gears instead. Similar pricing, and you will notice a far bigger difference in 3/4/5 than with just a Final Drive alone
Old Mar 8, 2008 | 07:34 AM
Default Re: (MFactory)
of course ive thought about the whole close ratio setup haha, but my bank account wont allow me to get it right now. im gonna do the trans in 2 stages most likely. so i can see the improvements.
thanks for the insight! youll be getting my order soon.
Old Mar 8, 2008 | 07:51 AM
2fastGSR's Avatar
King of the One Liners
Default Re: (killerpenguin21)
we had the best short times in our all motor hatch with a 4.9 fd and longer 1st gear if that helps at all.
But this was a track only car, cant comment on the street drivability of it . . .
Old Mar 8, 2008 | 09:07 AM
Teamdiesel's Avatar
Here is a vid with my JDM CTR using the Mfactory 3/4/5 gearset.
http://www.youtube.com/watch?v=bStnc47rWts
Old Mar 8, 2008 | 09:56 AM
98vtec's Avatar
moderator emeritus
Default Re: (Teamdiesel)
wow, 3rd gear sounds nasty
Old Mar 8, 2008 | 09:57 AM
Default Re: (2fastGSR)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 2fastGSR &raquo;</TD></TR><TR><TD CLASS="quote">we had the best short times in our all motor hatch with a 4.9 fd and longer 1st gear if that helps at all.
But this was a track only car, cant comment on the street drivability of it . . . </TD></TR></TABLE>
well its not a dd car anyway, so im not all that worried about the streetability. the only thing i want to keep is a good cruising 5th, so im pretty sure im gonna throw in an ls 5th for the like 300rpm's less in 5th while im in there.
Old Mar 8, 2008 | 04:15 PM
96Spec Ek's Avatar
We have very similar setups but I went with pro2's due to the fact I'm building a second motor which is bigger. I bought a s4c b16 tranny, obx lsd, mfactory 3.07 1st gear and 4.928 fd. Next purchases will be a set of 1-5 gearspeed synchros and a gsr 5th gear. You should get the 1st gear as well. It will help with your 60ft times.
Old Mar 8, 2008 | 04:46 PM
Default Re: (96Spec Ek)
did you do the fd and first at the same time?
Old Mar 8, 2008 | 07:53 PM
96Spec Ek's Avatar
Yes I am doing everything at once. I'm waiting on the synchros right now and a speedo gear. I would rather do it right the first time ya know. Putting that 4.9 in with a stock 1st gear is asking for traction problems.
Old Mar 8, 2008 | 08:05 PM
dragonz04's Avatar
Speaking from experience, i daily drive a bone stock gsr with itr transmission with stock lsd ats 4.9 fd and the ats 3.077 1st gear, it makes a hell of a difference from a dead stop, so for drag racing purposes yeah, i'd do it, but i'm loving the daily driving experience of my current setup but gas is a KILLER !!!!
Old Mar 8, 2008 | 08:14 PM
Default Re: (dragonz04)
yeah im just wondering if i can drop the extra 250 on the first gear...im quite broke, and need to get this piece together!
but it soundsl ike it owuld be the right thing to do....
Old Mar 8, 2008 | 08:37 PM
ok i just got myself confused.
an ls 5th gear is shorter than a b16 and gsr correct?
Old Mar 9, 2008 | 05:50 AM
MFactory's Avatar
No, the LS 5th is longer i.e You will achieve a higher top speed and slower acceleration
Old Mar 9, 2008 | 07:02 AM
yeah thats what i meant it was late haha.
Old Mar 9, 2008 | 08:48 AM
96Spec Ek's Avatar
Contact Walter Mckinney this is his phone # 304-692-2740 and website http://www.mckinneyraceworks.com/ He gave me a great deal on the final drive and 1st gear. Even on his website the prices are the best I've seen anywhere else. I spent about 20 minutes on the phone with him just bs'ing. He's a good guy who will answer all your questions if you have any.
Old Mar 9, 2008 | 06:58 PM
thanks for that, i put in email in to him since he doesnt have the first gear listed...good thing i did y taxes today!
Old Mar 9, 2008 | 08:23 PM
96Spec Ek's Avatar
He can get them though. Anyone have a hook up for gear speed synchros?
Old Mar 11, 2008 | 12:47 PM
still waiting to hear back from mckinney...hopefully soon i need to get all my parts in!
Old Mar 11, 2008 | 01:33 PM
Aquafina's Avatar
long first + short 3-4-5 &gt; higher FD anyday of the week. Pick the right gears for the gear set and it will work great for drag as well as track. Using the longer first with the gear set gives you a true cloe ratio box versus close ratio 3-4-5.
Old Mar 11, 2008 | 02:04 PM
acydphryck's Avatar
get a quaife gear box
