Throttle Body size
Alright Ive alread did the search on this to see if anyone has posted already and i didn't see anything. The motor is a b16a. Jus recently purchased a skunk2 mani. Wondering on size of throttle body with a motor thats going to be cammed?
Thanks
Thanks
Throttle body size depends primarily on the engine/cam combo.
Also, if you're running a larger plenum, you can use a small throttle body. If you're using a smaller plenum, you can use a larger throttle body.
I would stick with the stock throttle body in your case.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by .Hatches. »</TD></TR><TR><TD CLASS="quote">throttle body size depends on exhaust size. what size piping are you using?</TD></TR></TABLE>
The piping is 2.5.
Thanks!
The piping is 2.5.
Thanks!
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 92 white eg »</TD></TR><TR><TD CLASS="quote">
The piping is 2.5.
Thanks!</TD></TR></TABLE>
i'd say 68mm or 70mm
The piping is 2.5.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 1.888’rex »</TD></TR><TR><TD CLASS="quote">is it just a stock b16?
go type r and port it cant go wrong with type R
i had one on my gsr with type r manifold ran great!
or go 65mm
Yea..for the moment it is..but like I said its goin to be cammed here pretty soon!
or go 65mm
</TD></TR></TABLE>Yea..for the moment it is..but like I said its goin to be cammed here pretty soon!
