Ku engineering Intake mani
Old Mar 7, 2008 | 04:29 PM
TravisB16a's Avatar
Default Ku engineering Intake mani
Last year i bought a Ku manifold, i fell victim to its aweseom welds and mirror finish. i installed it on my car and it works, i never dyno'd after but i wish i would have. I had idle surging problems as well as not being able to keep a cruise at any speed , its was either constant accelaration or deaceleration never a steady cruise. Is there anyone that has the ku engineering intake manifold working consistantly ?
Old Mar 8, 2008 | 10:40 AM
victorpapa's Avatar
Default Re: Ku engineering Intake mani (TravisB16a)
A friend (eg6 b18swap) here in Italy run this manifold with 70mm tb and no problem at all.
He really enjoy this mani and he says it gives impressive power and torque .
You have only to move some ports and connect the idle valve control with a separate circuit
I'm going to buy one of this
Old Mar 8, 2008 | 12:54 PM
TravisB16a's Avatar
that is really good to hear . thanks alot . I also felt the increase in power , but i was always wondering if it was worth it because i would not run right. my idle surging sounded cool for about a week and the exhaust tone changed up alot . but not holding a cruise got old realy fast , and they hated me at the dirve through .... with the car idleing it did .
Old Mar 8, 2008 | 10:55 PM
victorpapa's Avatar
Default Re: (TravisB16a)
I think your problem is only the right connection to the idle valve control.
Take a look to this pic, this is the way he connected the idle valve to the manifold and to the OCT. The valve is now separate from the manifold
He closed the original ports and opened others
I hope the pics can help you
Modified by victorpapa at 4:50 AM 3/9/2008
Old Mar 9, 2008 | 12:13 AM
Fat Chick Magnet's Avatar
what a weird *** intake manifold..
Old Mar 9, 2008 | 09:40 AM
pr0honda's Avatar
Default Re: (Fat Chick Magnet)
does it have velocity stacks at the end of each runner?
Old Mar 9, 2008 | 09:47 AM
Combustion Contraption's Avatar
It actually "looks" like a pretty good design
Old Mar 9, 2008 | 10:04 AM
UncleD's Avatar
Default Re: (Combustion Contraption)
Like the Full Race manifold..
Old Mar 9, 2008 | 10:14 AM
TravisB16a's Avatar
each has individual stacks with fluted ends
Old Mar 9, 2008 | 10:20 AM
TravisB16a's Avatar
this is an inside shot , you can find these on ebay they also offer a 75mm tb to match
Old Mar 9, 2008 | 11:32 AM
2point6's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by TravisB16a &raquo;</TD></TR><TR><TD CLASS="quote">
this is an inside shot , you can find these on ebay they also offer a 75mm tb to match</TD></TR></TABLE>
Could you post a link as to where I can buy one? I would like to do some testing.
Old Mar 9, 2008 | 12:53 PM
mar778c's Avatar
Community Builder
Community Influencer
You have an ecu codes? Surging idle sounds like a IACV or tps problem. The problem with steady-state operation sounds like a O2 sensor problem.
Old Mar 10, 2008 | 02:55 PM
TravisB16a's Avatar
there is a code and it came up iacv inop
. and i will deffianalty try the o2 sensor , at first thats what i thought was causing the idle surging
Old Mar 10, 2008 | 02:59 PM
TravisB16a's Avatar
http://www.japengineshop.com/i...e=777 - 19k -
Old Mar 10, 2008 | 03:02 PM
TravisB16a's Avatar
go to that link and click ebay items . you can also search b intake manifold on ebay and you can find it there
chris478
Mar 11, 2007 01:31 PM
jumpman83
Oct 16, 2005 01:45 PM
JTCdudeman
Sep 4, 2005 05:51 AM
mr. carpenter
Apr 17, 2005 07:13 PM
