Valves? Ferrea vs Omni?
Old Mar 7, 2008 | 12:13 PM
PARADOX_sf's Avatar
Default Valves? Ferrea vs Omni?
I am building turbo B16. Which valves are better - Ferrea Competition Plus Valves or Omni's valves? Why?
Ferrea:
Ferrea Competition Plus Valves have built a reputation as the industry's most reliable extreme duty valve. We, at Ferrea, are dedicated to providing the absolute best product on the market.
Our extensive R & D programs provide tehcnological gains, which are implemented in each of our competiton plus valves. They are engineered for higt rpm, high horsepower racing engines, and are chose by many top NASCAR, Drag, and Oval & Sprint Car-racing teams.
To manufacture the valves we use special aerospace quality alloys, including EV8-Z18, which provides high tensile strength. An exclusive two-step slow forging process ensures proper grain flow and virtually eliminated any damage to the material structure. The valves are then heat treated and stress-relieved over a 48-hour period, which is the crucial base of our molecular integrity. These valves feature avionics-quality hard chrome along with a specially applied hard tip. Our engineering staff at Ferrea spends countless hours conducting flow bench tests to achieve an optimum balance of flow, velocity and efficiency in the design of this valve. As a result, these valves incorporate smoother radiuses and unique undercuts. These exclusive features are what make the Ferrea Competition Plus Valves unequaled in performance and reliability!
Ferrea is once again setting the pace with its Competition Plus PQ Series Exhaust Valves, the next generation of exhaust valve technology.
Due to the evolution in today's competition engine applications, temperatures are increasing and as a result, longevity is decreasing. Therefore, Ferrea is pleased to introduce our NEW! Competition Plus PQ Series Valve.
This is a next generation exhaust valve made of an Ultra High Strength, High Temp Nickel Stainless Stell Alloy. Ferrea first used this material with great success during the development of a very high stress, high temp endurance racing program.
This PQ Series next generation exhaust valve material will progressively replace Competition Plus Series valves as applications evolve and the material becomes necessary.
Listed below are some qualities of the Next Generation Exhaust Valve material:
Tensile strength increased by 20% at high temperature
Fatigue resistance increased by 20%
Valve seat life increased by 25%
Omni:
Omni-Power valves are constructed with both performance and OEM reliability in mind. Our intake valve is a 1 piece forging using Japanese SUH-11 stainless steel. This material is suitable for both high temperatures and has the hardness required to prevent the valve tip from mushrooming during extreme use. Our exhaust valve is a 2 piece friction welded forging that uses an NCF-751 Inconel head, mated to an SUH-11 stem. This provides the ultimate combination of material for both extreme temperatures and valve stem tip fatigue resistance. A flat bottom design is used to increase compression ratios by .3-.5 depending on engine size. Omni-Power valves are much stronger and last longer than EV-8 valves as well as many other aftermarket valves. Omni-Power valves are also available in standard compression for N/A and Turbo applications.
Old Mar 7, 2008 | 01:32 PM
98vtec's Avatar
moderator emeritus
Default Re: Valves? Ferrea vs Omni? (PARADOX_sf)
dont believe you could go wrong with either.
and i dont believe there are many people here who could really tell you which one is better.
Old Mar 7, 2008 | 01:37 PM
DonF's Avatar
Default Re: Valves? Ferrea vs Omni? (98vtec)
For a turbo, I would probably select ferrea, as they would disapate heat better. Ask on the forced induction area, they would know better.
PARADOX_sf
Mar 10, 2008 11:50 AM
Boostage
Dec 29, 2005 04:23 PM
Boostage
Sep 15, 2005 05:35 PM
