Official **H series** Camshaft Thread
Old Mar 7, 2008 | 11:02 AM
98vtec's Avatar
moderator emeritus
Default Official ** H series** Camshaft Thread
No more individual topics of "what cam is best" will be accepted from this point on.
Rules:
1) DO NOT POST WITHOUT EXPERIENCE
2) GIVE DETAILED INFORMATION - why did you pick your cam?
3) PROVIDE EMPIRICAL (real) EVIDENCE OF HOW THE ENGINE PERFORMS
- Dyno charts, time slips, anything
4) THIS IS NOT FOR COMPARING DYNO NUMBERS
- different dyno's read differently. read the GRAPHS
5) <FONT SIZE="5">NO COMMENTS PLEASE</FONT>
Offtopic posts will be deleted.
Old Mar 7, 2008 | 12:05 PM
98vtec's Avatar
moderator emeritus
Default Re: Official ** H series** Camshaft Thread (98vtec)
175whp = stock cams
188whp = stock cams with EuroR IM
193whp = Crower stage 2 cams with EuroR IM
with 175whp in a 1998 Honda Prelude, the car went 14.0 at 96.6 with the following modifications:
stock internal h22a
short ram intake with Bpi flowstack
RMF header
2.25" catback
stock ported IM with blacktrax spacer
s2000 throttle body
Crome Pro
no ac, ps, cruise..etc
22x8x15 MT ET drag
Not too long after the dyno of 193whp with the crower cams, i found that they had eaten into the rocker pads. I came to believe that the reason why the cams did not make significantly more power and why the power graph was weird.
I never got a chance to run the car at the track with 188whp or 193whp as i was afraid of popping an axle but i am a firm believer that the car would have busted a mid 13 or so.
Old Mar 7, 2008 | 02:08 PM
VtecKiDD's Avatar
Stock h22 block
Skunk2 PRO1 Camshafts
Skunk2 Valvesprings and Retainers
Skunk2 Flat Faced Valves
RSR header
2.5in crush bent exhaust
Tuned with Crome Pro
Old Mar 7, 2008 | 03:36 PM
snzh22's Avatar
H22A1 10:1 CR 126k miles
Skunk2 Pro1 Cams
Supertech springs and retainers
Ebay header (50mm), Megan test pipe (60mm), RSR Exhaust (60mm)
AEM CAI
Blacktrax spacer
STOCK: Block, Valves, IM, TB
Tuned by Chris @ XENOCRON on eCtune.
3rd gear pulls
just for reference, an ITR with bolt-ons and smsp header made 178whp on this dyno.
i chose these cams because of the previous post. saw awesome gains on a relatively stock motor. my older dyno with a different header had a huge dip right in the power band (5500-6500rpm). i suspected that the problem was because of lack of compression because i was on stock compression. the real reason was because i was using the camp1320 header, which has a 2.5" collector and it bottle necked down to 2.36" exhaust. either it was the bottle neck effect or it was the header itself. either way, i have better results with the ebay header.
Modified by snzh22 at 5:05 PM 3/7/2008
Old Mar 9, 2008 | 01:07 PM
98vtec's Avatar
moderator emeritus
The Birdmans H22
89x95
12:1 cr
pump gas
RLZ headwork and custom intake mani w/ 70mm tb
RMF header
JUN cams
Carillo Rods
Custom Comp. Height Wiseco pistons
Fidanza flywheel
CM stg 3
ferrea valves and valve guides
jg springs and retainers
custom 3" exhaust w/burns stainless 2.5-3" adapter and n1 fart can
m2b4 stock lsd tranny (looking to change in the future)
UR crank pulley
removed balance shafts
Old Mar 9, 2008 | 01:14 PM
98vtec's Avatar
moderator emeritus
Old Mar 9, 2008 | 01:17 PM
98vtec's Avatar
moderator emeritus
member "skunked"
Stock USDM H22 longblock (10:2:1)
crower stage 3 cams
six sigma header
68mm Holley
Tuned with a fields controller
Old Mar 9, 2008 | 01:22 PM
98vtec's Avatar
moderator emeritus
H23A
Crower stg 2 cams
RPM 68-70 mm TB
Skunk2 IM
3 inch intake
Hot Shot header 2 1/2 inch w/ 2 1/2 piping
manual tensioner done
Golden eagle cam gears
255 walboro fuel pump I was running nitrous on the car sometimes
profab fpr
SI Valve springs, valves and retainers. Not a civic si. SI They are a shop in simi valley california
Old Mar 9, 2008 | 01:23 PM
98vtec's Avatar
moderator emeritus
alaniz headwork
skunk 2 stage 2 cams
H22 block with stock crank,CP 12.5:1 pistons, 89mm bore
venom intake manifold
RC440 injectors
hondata s200
70mm TB
Old Mar 11, 2008 | 09:35 PM
snzh22's Avatar
lude98SH
H22a
Skunk2 Stage 1 Cams
BPI velocity Stack
AEM 3 inch intake
68mm AEBS TB
Accord Euro R manifold plenum portmatched to TB and runners ported
PP head
3 angle valve job on intake and radius on exhaust
Supertech Flat faced valves
Supertech valve springs
Supertech titanium retainers
Single Layer Headgasket
KaizenSpeed BalanceShaft Eliminator kit
Lightweight Flywheel
UR ultra R crank pulley
Camp1320 header (open)
EH3forlife
12
Aug 4, 2010 02:39 AM
johnny_bighood
11
Apr 29, 2009 10:14 AM
teri_vti
16
Sep 18, 2007 12:03 AM
94vtecmn
May 13, 2003 02:04 PM
Anubyss
Jul 16, 2002 03:14 PM
