civic auto to 5speed swap revised lol
oke many of u guys who are thinking of doing a auto to 5 speed swap are thinking what parts do i need there are some parts that thay dont list in like the rear and frount and side motor mounts because the ones that the auto come with are off and dont line up well thay also for got to tell u to get to the rear mount to get it off u got to semi drop the cross member to get to the bolt in the back of the mount also i figured out how to get the holes pluged with out welding
first lets start with the long hole where the cable came threw u just take the old mount that holds the cable cut the bottem half and hammer it flat till u can put some rivits in to it to hold it down and jb weld the cracks
and tar over it after words or use a good sealer i used head permanex extream copper
that stuff hardens like a rock and its a pain to remove lol then u just need to inlargen the holes near the shifter sidde enouf to fit i nut threw them because what i did was i cut the section out of a 5 speed ef in the yeard and drilled all the pinch welds and took it apart the floor shifter section on a 5 speed has holes with bolts welded to them so what i did was i used them to hold the pice in and jb welded it and tared it and sealed it well it worked also gave me a template where to drill the holes also another + then all u need to do is reuse some washers form ur auto stick and put them back where thay came from on the bottem side also if u want u can put anti seze i did that to every bolt in ur 91 ef sedan
and ur done
all leak proofed and sealed and works like a charm
if u want i can take some pics and post them up i just need to get time to put them thay will be posted also if u eney one wants i will be selling kits to make cars to 2 speed the 5 plug plates for the holes for a cheep price and thay will be welded no jb weld
lol
and ur done
all leak proofed and sealed and works like a charm if u want i can take some pics and post them up i just need to get time to put them thay will be posted also if u eney one wants i will be selling kits to make cars to 2 speed the 5 plug plates for the holes for a cheep price and thay will be welded no jb weld
lol
I covered most of the details pretty thouroughly in this thread...
https://honda-tech.com/zerothread?id=2237928
