Re: Why is my 86 civic overheating!? Read what I've done, see if one of you can diagnose the problem
I can guess a couple things off the top of my head.
1) Possibly you have a bad radiator fan switch
2) Possibly your temp. gauge is faulty
3) Something is clogging your radiator causing it not to flow correctly
4) You have a airleak somewhere in your cooling system
have you replaced your waterpump? I see you checked it for leaks, but like most pumps, if it sucking air in, it may not show a leak out. regardless, I would focus my attention from the inlet of the water pump back.
Actually, the water pump I have in there now came from a civic with 67 000kms on it. The only reason it was in the wreckers was because it had a blown hondamatic tranny. It made no difference, felt just like my other one too, both are in good shape. I have checked all the coolant lines very thoroughly they are in good shape. Yep, I bled air out several times but as soon as I start driving more air gets in and stops coolant flow. Just did the timing when I put this last head on. I went to the junkyard today and grabbed a block, gonna wait until school is done and do the swap, I have done absolutely everything and nothing has fixed it...Won't I look like a fool if it doesn't, oh well i have to try. Thanks for the reply scott.
Have you tried letting it sit and idle for a while... Does air get in then?
I'm not sure I understood what you meant by one of your comments. Someone asked you if you were losing coolant and you said no. How are you not losing coolant and yet gaining air?
Other question... Do you have an aftermarket overflow reservoir? Is the hose from your radiator cap going to the bottom of the overflow reservoir? Because the hose from the cap has to be able to pull the coolant back into the radiator as the pressure changes. So, even if you have the OEM overflow reservoir, and the coolant tube isn't able to pull fluid back in, it would start pulling air.
Do you have access to a auto grade smoke machine? We have one in the lab at school. If you do, totally drain your system, find an adapter and fill that coolant system full of smoke. Where it comes out is where your problem is... You're probably going to have to stopper your overflow reservoir air bleed as well.
Best of luck!!
I talked to one of my professors today and he seemed to second the cracked block idea, however he also said that a single test was worth a billion opinions...
The idea he came up with is to take an emissions tester wand and wave it over the open radiator... if you're getting hydrocarbons (fuel), it's a cracked block...
Apparently there's a tester with a name something to the effect of "Block Tester" that used a blue fluid that air is pulled through, apparently changing colors depending on the hydrocarbon level. It's also used above the open radiator.
Thanks a lot for going out of your way to ask your proff. about my problem, I appreciate that. I had looked at doing a combustion leak test, but the kit from Napa is like $50. I am fairly confident that it is a cracked block, so I'm just gonna go ahead and swap the engine at the end of April, after exams. If the new block solves the problem and it is good, I'll throw on new crankcase gasket set, and rings, maybe rod and main bearings, and I'll have a good running car for the next few years.
So it's 2023 and I have an 86 crx si with the exact same problem..been fighting it for 2yrs..did you ever figure out the problem? I've replaced my water pump and just tore down for head gasket..head gasket still like new..got 40000 on it and still mint.. irritating as hell
There was a talk some time ago on redpepperracing dot com about the different water pumps avail for our engines, and of course various non-OEM brands have different impellers , here is what I saved, the 515 has a slightly larger impeller
