Heater/ac wont blow air
I have an 02 acura rsx (auto). I turned the **** to the highest setting for heat and no air blows out of the vents and I do the same thing for cold/ac. Nothing comes out still.. My temp. gauge is normal. Could there be a fuse under the dash that's open?
There are (obviously) three control *****. One selects fan speed/auto, one sets the temperature, and the third one directs the air flow/auto. Did you try turning the fan speed ****, or just the temp control?
Could be an open fuse, I can't tell from here.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Perfectionist »</TD></TR><TR><TD CLASS="quote">There are (obviously) three control *****. One selects fan speed/auto, one sets the temperature, and the third one directs the air flow/auto. Did you try turning the fan speed ****, or just the temp control?
Could be an open fuse, I can't tell from here.</TD></TR></TABLE>
Yeah i turned the fan speed **** also. If it is a fuse would it be under the dash because i checked the heater fuse under hood and it looks good still.. I dont have a fuse cover under the dash so which one would it be? Thanks for the input man
vinny31
May 7, 2018 10:38 AM
chaz6416
Jun 17, 2010 05:29 AM
