Question about front sway bar on del sol
Guys,
I have a quick question. I just bought a 94 del sol S. Which has a oem sway bar. My question is I had a 95 4 door eg that was stolen but all the suspension is there. Can I take the front sway bar from there and use it on the sol? The reason why i need to replace it is on the front control arms where the sway bar bolts down to the control arm it looks like its rusted out or the bushing and stud snapped off. Can i take the control arm from the 4 door and also put it on the sol?
thanks
thanks
94 Del Slo and 95 Civic should share suspension components.
Front lower LCAs should be interchangeable.
I believe the Del Sol and Civic sway bars are the same shape, which then you'll be able to use the endlinks. You can also buy Energy Suspension endlinks too.
Not sure if they changed it for 94, but I know for a fact that the 93 S did not have a front sway bar. The Si does. Having owned three 93's, and two friends with 93 S models, I've had to swap out the arms before. Everything should change over fine.
phantom_sol
Apr 6, 2003 05:11 PM
