Honda Civic (2006 - 2015) 2006 - 2015 Civic Forums
"06" vs. "07+ " bushings/SS package. aren't they the same??
Old Mar 7, 2008 | 06:28 AM
jaepalm's Avatar
Default "06" vs. "07+ " bushings/SS package. aren't they the same??
http://www.corsportusa.com/sto...=1879
http://www.corsportusa.com/sto...=1880
Looks the same to me? WTF?
I have an 08, should i go for the newer ones and just not risk it?
Old Mar 7, 2008 | 07:44 AM
WILD_WILL's Avatar
Default Re: "06" vs. "07+ " bushings/SS package. aren't they the same?? (jaepalm)
They fit slightly different i would go with the 07's set to be sure i doubt they changed it from 07 !
Old Mar 7, 2008 | 09:49 AM
john_07si's Avatar
Default Re: "06" vs. "07+ " bushings/SS package. aren't they the same?? (WILD_WILL)
they are different.... every year is a little deifferent so if you want tthe best fit ..and dont want to risk it just get it from
http://www.twmperformance.com i got mine for my( 07, si) it workss really good ..!
Old Mar 7, 2008 | 10:31 AM
jaepalm's Avatar
Default Re: "06" vs. "07+ " bushings/SS package. aren't they the same?? (john_07si)
they offer both base and cable bushings. Whats the difference? do i need both? why?
Old Mar 7, 2008 | 10:39 AM
john_07si's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by jaepalm &raquo;</TD></TR><TR><TD CLASS="quote">they offer both base and cable bushings. Whats the difference? do i need both? why?</TD></TR></TABLE>
yes you need both cause the base is to make the shift shorter .and the cable bushings is to make it nice and stifff when you put it into gear ..! yes you need both man ..
Old Mar 7, 2008 | 11:59 AM
jaepalm's Avatar
whoops. Just ordered the SS with only cable bushings for express mail. All i want is for it to eliminate the notchiness which bothers my recently broken/separated shoulder. Kevin from TWM told me over the phone that it wasn't necessary to get the base ones in my case.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by john_07si &raquo;</TD></TR><TR><TD CLASS="quote">
yes you need both cause the base is to make the shift shorter .and the cable bushings is to make it nice and stifff when you put it into gear ..! yes you need both man .. </TD></TR></TABLE>
doesn't the shortshifter make it a....shortshifter???
Did i F up?
Old Mar 8, 2008 | 07:16 PM
hondamanforlife's Avatar
no! just a shorter trow. you should get the alum bushings to compleat the feal! if your having trouble with 3rd go to norris honda in dundalk and tell them you're problem . they are replacing my sycros right now.
Old Mar 8, 2008 | 07:46 PM
07galaxygrey4dr's Avatar
will the bushings cause premature wear?
B20Monster
15
May 15, 2007 03:07 PM
MSchu
Honda Motorcycles
Jun 9, 2006 12:48 PM
professorman
Honda Motorcycles
Feb 2, 2006 01:31 PM
