i need hel whit my tranny
i have a h22a4 but the tranny have the unit called ATTS soo that it works???? if I do not connect it that it happens??? if I put it without connecting sensors???? what happened....
Why do you want to leave the atts disconnected?
you can just leave the atts unit unplugged and it will be non functional. your car will drive fine without it. your light on the dashboard will be on.
he lives in Mexico, so it probably isn't. It sounds like he is using a computer translator or something.
So your question is, can you just leave the atts disconnected and have a perfectly good working transmission?
Yes, the car would work fine with out the ATTS cable unplugged, but the ATTS light on your day will come on.
What the ATTS (Active torque transfer System) it’s just like an LSD Limited Slip differential. Its good for when you need traction and also the car will handle better.
Spanish:
El carro si se va a manerjar bien si el cable esta desconectando del ATTS. Pero la luz en el tacometro se va a ensender. Lo que hase el ATTS es un diferencial positivo electronico, hase que el carro tenga superior control que un carro que no esta equipado con ATTS
Spanish:
