Skunk2 pro1's, pro2's or Tuner Stage 2???
Old Mar 7, 2008 | 05:13 AM
Eg6DR's Avatar
Default Skunk2 pro1's, pro2's or Tuner Stage 2???
Hi guys Im still not sure where to go cam wise with my setup, I want something that'd give me the most power but able to go as daily driver
B18c1 Engine
Options are Skunk2
Pro 1
Pro2
Tuner stage 2
-Other options are welcome (please back your choise with some info)
what you think?
here's the setup:
Edelbrock 65mm TB
Edelbrock performer X IM
Complete built GSR head and valvetrain (portflow)
JDM ITR .25 oversized pistons
GSR rods
Balanced crank
Hytech Replica Header
Modified by Eg6DR at 10:24 AM 3/7/2008
Old Mar 7, 2008 | 05:25 AM
polishedturd's Avatar
I like PIE
i have asked this very same wuestion with the same cam options and someone told me to ask my tuner what he is comfortable with and what he feels will get the most out of your setup. the truth is every setup is different and you wont really know until you get it on a dyno and try them out. i have seen good power with all of those cams. the stg 2 or pro 1's would be my choice for a dd.
Old Mar 7, 2008 | 06:39 AM
.:si:.'s Avatar
Default Re: Skunk2 pro1's, pro2's or Tuner Stage 2??? (Eg6DR)
pro 1's
Old Mar 7, 2008 | 08:36 AM
98vtec's Avatar
moderator emeritus
do you have anything to degree the cams?
Old Mar 7, 2008 | 08:57 AM
Eg6DR's Avatar
Yep, Have skunk2 cam gears
Old Mar 7, 2008 | 09:01 AM
98vtec's Avatar
moderator emeritus
Default Re: (Eg6DR)
no. I mean a cam degree fixture.
Old Mar 7, 2008 | 09:18 AM
Eg6DR's Avatar
Default Re: (98vtec)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 98vtec &raquo;</TD></TR><TR><TD CLASS="quote">no. I mean a cam degree fixture.
I've got absolubtly no idea what that is..
Im pretty sure my mechanic will, (I THINK)
Old Mar 7, 2008 | 09:19 AM
98vtec's Avatar
moderator emeritus
Default Re: (Eg6DR)
i would stick to the tuner cams then.
Old Mar 7, 2008 | 10:15 AM
cartune network's Avatar
i would go with tuner cams unless you bring the head to a builder and have them install the cams, gears and degree the cams. if your gonna do that then go with the pro 1's pro 2's might be too much for that motor.
Old Mar 7, 2008 | 11:02 AM
turboZChatch's Avatar
Default Re: (cartune network)
I would say that the pro 2's are a little big for your setup...and as 98vtec implied if you are having someone whom has the knowledge as to how to degree the cams in then go with pro 1's if your going to be putting in the cams and bringing it somewere to get tuned go with the tuner stage 2's (still need knowledge but a lot easier for your average enthusiast to install) either one of those 2 cams will compliment your setup well........good luck
Old Mar 7, 2008 | 02:49 PM
00Red_SiR's Avatar
All Motor Mentor
engine management?
Old Mar 7, 2008 | 05:02 PM
Eg6DR's Avatar
Just finished buying everything today (its all being shipped at the moment)
65mm Edelbrock TB
Edelbrock PerformerX IM
Hondata IMG
Complete built GSR Head and valvetrain by Portflow
Skunk2 Pro1 Cams
ARP head Studs
JDM ITR pistons
OEM head gasket
ARP rod bolts
Stock GSR rods
OEM bearings
Balanced Crank
Hytech Header
H22 injectors
MSD 6AL with external Coil
-Tuned on Chipped P30 ECu with Crome
Hoping we can put down low 200's whp. Ill let you all now how it goes
Old Mar 7, 2008 | 05:06 PM
Fat Chick Magnet's Avatar
I would go with tuner series stage 2's.
Old Mar 7, 2008 | 05:31 PM
00Red_SiR's Avatar
All Motor Mentor
Default Re: (Fat Chick Magnet)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Fat Chick Magnet &raquo;</TD></TR><TR><TD CLASS="quote">I would go with tuner series stage 2's.</TD></TR></TABLE>
why? pro 1's will be better if he has a competent tuner.
Old Mar 7, 2008 | 05:44 PM
oldskool teggy's Avatar
Default Re: (00Red_SiR)
you might actually want larger than h22 injectors. I'm at 99% duty cycle above 8000 rpm with mine using s2s2 cams. get an adj. FPR as a quick fix
Old Mar 8, 2008 | 10:48 AM
johnsonfire17's Avatar
I would go with tuner series stage 2's. +1
Old Mar 8, 2008 | 04:21 PM
lilryan's Avatar
he already bought cams
Old Mar 8, 2008 | 04:50 PM
Eg6DR's Avatar
Ill let you all now when we start tuning. hope we hit 200whp
Old Mar 8, 2008 | 11:57 PM
BMo Tuning's Avatar
STAR
This ain't no SOHC A DOCK.
I must admit I did LOL when I saw your picture of a cam fixture........I figured you meant cam gears when you asked about the OP having anything for cam adjusting.......seeing that you really meant a cam fixture had me lol'ing...........I'm such a loser......lol.
I realize my post adds nothing to this thread and I apologize.
Old Mar 9, 2008 | 12:10 AM
what cams you buy?
Old Mar 9, 2008 | 05:00 PM
Eg6DR's Avatar
Got Skunk2 Pro 1's
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by oldskool teggy &raquo;</TD></TR><TR><TD CLASS="quote">you might actually want larger than h22 injectors. I'm at 99% duty cycle above 8000 rpm with mine using s2s2 cams. get an adj. FPR as a quick fix</TD></TR></TABLE>
H22 inj. Im not really sure about the size because these are OBD1 inj. I know that OBD2 ones are a bit smaller (270-290cc)
What injectors size would be optimal? also, is the stock fuel pump good enough? I have a 93 CX hatch.
Old Mar 9, 2008 | 05:47 PM
Default Re: (Eg6DR)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Eg6DR &raquo;</TD></TR><TR><TD CLASS="quote">Got Skunk2 Pro 1's
What injectors size would be optimal? also, is the stock fuel pump good enough? I have a 93 CX hatch.</TD></TR></TABLE>
usually with cams i just get fuel injectors like RC 310's/FPR.
Old Mar 9, 2008 | 07:01 PM
civic*gsr's Avatar
Eg6DR, I'm doing almost the same set up with my gsr civic, I have the skunk2 im, 4-1 header,pro 65 mm throttle body, k&n intake, and just got some skunk2 pro 1 with skunk gears and valvetrain, my question is who are you using to do your set up, because I don't trust anybody with my car, do you know well the shop or people that are working on your car.
Old Mar 10, 2008 | 12:36 AM
anothersickhatch's Avatar
Default Re: Skunk2 pro1's, pro2's or Tuner Stage 2??? (civic*gsr)
i would get a walbro fuel pump and larger injectors. ill tell you right now with my experience, you are going to run out of fuel when you get it tuned. stock injectors kept me at 206 whp, even with a 255 fuel pump. once i had it re-tuned with rc 310's and a 2-layer headgasket, it jumped to 220 whp. sean at church automotive testing told me that i would have ran out of injector and around 210.
Old Mar 10, 2008 | 08:53 AM
ilikehonda's Avatar
obdI h22 injectors are 345cc
