b16 piston clearence question
ok guys im building my b16a and i was looking to buy the arias .....81.50 mm bore / +7.4 dome / 11.3 compression i was wondering if that dome size is safe enought to use with a stock stroke? Will it hit the valves? thanks for yur inputs
Aftermarket pistons usually have deeper valve reliefs to accomodate higher lift/longer duration camshafts, so you will be OK with the stock stuff.
Guess what the only real way to find out is?
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Combustion Contraption »</TD></TR><TR><TD CLASS="quote">Aftermarket pistons usually have deeper valve reliefs to accomodate higher lift/longer duration camshafts, so you will be OK with the stock stuff.
Guess what the only real way to find out is?</TD></TR></TABLE>
do more work?!?! HELL NO... remember HT is full of lazy bastards
ha ha yea ive been on the net for a while searching this topic...... if i want to go with the stock bore which is 81.00mm but get my block cleaned and get it re-cross hatched (honed right?) wont that change my bore size? Or should i just go .25mm oversized so i can get the honed already included
I found these guys that sell the pistons
http://twincamtech.stores.yaho....html
throw the motor together and slap some modeling clay or play-doh on the piston then rotate the motor and if the valves touch then their indents will remain in the clay
BlkChryKord
Jan 17, 2006 02:55 PM
