Harness Pins
Old Mar 6, 2008 | 06:47 PM
no1knows908's Avatar
Default Harness Pins
When I do my H22A swap I know I will have to wire in the VTEC solenoid and pressure switch. Problem is I searched the forums and Google and I can't find out where to get new pins for the ECU and engine side harnesses. I want to keep the install as clean as possible. I'm just gonna get the connectors from the junkyard but I really don't want to try to uncrimp then reuse pins. Can I get these from the dealer?
Old Mar 6, 2008 | 06:57 PM
Acidcrakker's Avatar
Default Re: Harness Pins (no1knows908)
Yeah for 1000 bucks. They wont sell you just the pins. But you can pick them up yourself at something like a radio shack. There is also a dude on here that I got mine from for 10 bucks. Its like Chatik or something like that. His name is hard to remember.
Old Mar 6, 2008 | 07:12 PM
Would these work?
Old Mar 7, 2008 | 04:45 AM
I dont know, you need one smaller pin and one larger pin. Best bet is to pull a pin out of the ecu and walk into radio shack with it, and go, I need one of these.
Old Mar 8, 2008 | 08:07 AM
CHK4TIX's Avatar
Default Re: Harness Pins (Acidcrakker)
protip: check my sig
holmesnmanny
Dec 19, 2010 03:07 AM
90Rexx
Mar 26, 2009 12:30 PM
vladd
Dec 15, 2006 01:26 PM
mcgee*
Jun 8, 2006 07:29 AM
85mm LS VTEC
Mar 11, 2005 05:10 PM
