Missing Hoses... where to?
Old Mar 6, 2008 | 02:59 PM
cuteboi's Avatar
Default Missing Hoses... where to?
Missing these connections... where do they go?
Engine is D15B1 stock... all stock... no, I will not do a conversion...
http://legendro.net/~anthony/i...4.JPG
The one from the valve cover I was told is a breather, and needs to dump into the intake, so I will do that. but that rubber hose goes where? where should I make it go to? I have some hoses that fit that one and I could cut a new one... if only I knew where it went to.
http://legendro.net/~anthony/i...9.JPG
I was thinking this connection connected to the upper rubber hose... but I need some sort of confirmation.
Old Mar 6, 2008 | 03:24 PM
SIred91's Avatar
Rainman
Default Re: Missing Hoses... where to? (cuteboi)
Shouldn't that be your PCV valve?
Old Mar 6, 2008 | 04:10 PM
cuteboi's Avatar
This is the PCV valve, and it's connected to the oil pressure relief... This is already hooked up.
Old Mar 6, 2008 | 04:28 PM
SIred91's Avatar
Rainman
Default Re: (cuteboi)
Hmm......you got me then man......Im not up on my DPFI folklore....
Old Mar 6, 2008 | 04:33 PM
cuteboi's Avatar
But this is on the lower block, the bottom hose is on the lower block, not the intake manifold.
Old Mar 6, 2008 | 04:40 PM
SIred91's Avatar
Rainman
I would guess that the hose in your first pic goes to the intake then,,,,,but I dont really know how DPFI is set up..
Old Mar 6, 2008 | 05:03 PM
88DXCRX's Avatar
From: I told you to wait in the truck in Texas, United States
Default Re: (SIred91)
Hook those two together with 5/16" hose...
Modified by 88DXCRX at 8:16 PM 3/6/2008
Old Mar 6, 2008 | 05:23 PM
cuteboi's Avatar
Default Re: (88DXCRX)
Perfect, this will get connected, I will finish up the electrical, and find out if he car starts up.
Old Mar 7, 2008 | 05:46 PM
SIred91's Avatar
Rainman
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by cuteboi &raquo;</TD></TR><TR><TD CLASS="quote">Perfect, this will get connected, I will finish up the electrical, and find out if he car starts up.</TD></TR></TABLE>
X2......I looked at my friends car....those two hoses connect to each other. You are just missing the metal link that connects them.
s10cky
Nov 20, 2006 12:24 AM
vietnamese0utlawz
May 19, 2006 09:46 PM
hondadriver
Mar 14, 2006 08:03 AM
x91civichatch
Nov 14, 2005 03:21 PM
DCStreetHtch
Feb 27, 2003 05:59 PM
