B18c6 over bore question
Old Mar 6, 2008 | 01:56 PM
12sec14's Avatar
Default B18c6 over bore question
My girlfriend drives a EF8 CRX siR. It has a B18c6 in it and Smokes a good un' when giving some stick.
I am collecting parts before the big rebuild. I have Cams (pro 2's) Will soon have Valve train.
Next is Pistons and Rods!
NOW I have read that 82mm is pushing it on stock sleeves. The CR will be 12.5:1
These Pistons will be JE pistons and I would like them to be 81.25mm.
Will I still get good reliability with that much of an over bore and the high comp?
Thanks, Paul.
Old Mar 6, 2008 | 03:22 PM
00Red_SiR's Avatar
All Motor Mentor
Default Re: B18c6 over bore question (12sec14)
That's fine for overbore size but I think you should rethink your cam choice. What you have will work but I believe there are better choices (think slightly smaller).
Old Mar 6, 2008 | 03:25 PM
Combustion Contraption's Avatar
Engine management?
Old Mar 6, 2008 | 03:46 PM
DonF's Avatar
Default Re: (Combustion Contraption)
Seeing wher you are, I would check Accralite pistons, they do 81.5 and 82mm. They are better than the pistons you have mentioned, just cost too much here with the dollar value.
Old Mar 6, 2008 | 10:21 PM
12sec14's Avatar
Default Re: (DonF)
Engine will be tuned with Crome Pro.
Also I get a pretty good deal on Eagle rods and JE piston combo's as its almost $2 to the £1. Also my Mom lives in Biloxi so she is able to forward parts to me.
Am I going to face any problems with JE pistons? I have searched but not found anything negative about them.
I was under the impression that with a CR of 12.5:1 that I would have more gains with Pro 2's rather than Pro 1's.
Do you think that the Engine will be over Cammed?
Old Mar 7, 2008 | 03:30 AM
cyber gook's Avatar
Default Re: (12sec14)
Hi mate, I'm based in the UK and have some 81.5mm Toda Forged pistons to sell. I am moving to an 85mm sleeved set up so no longer require them if your interested.
Old Mar 7, 2008 | 04:02 AM
00Red_SiR's Avatar
All Motor Mentor
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 12sec14 &raquo;</TD></TR><TR><TD CLASS="quote">I was under the impression that with a CR of 12.5:1 that I would have more gains with Pro 2's rather than Pro 1's.
Compression is only one part of the equation, displacement is another important part. Pro 2's will work in your engine, they will work better in a 1.9L - 2.0L+ engine and that compression ratio. If this car is mostly a street car with some occasional race use, I would look more towards the pro 1's. If it's used mostly as a track car, you can use pro 2's. In the end it's your choice, just giving you something to think about.
Old Mar 23, 2008 | 05:10 PM
donut.'s Avatar
theres a guy on here that made 230ish with pro2's and a stock itr block lol
Old Mar 23, 2008 | 06:06 PM
00Red_SiR's Avatar
All Motor Mentor
Default Re: (donut.)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by donut. &raquo;</TD></TR><TR><TD CLASS="quote">theres a guy on here that made 230ish with pro2's and a stock itr block lol</TD></TR></TABLE>
Show me.
mitchh29
Apr 23, 2013 05:29 AM
92CHB
Oct 10, 2011 07:36 AM
Bonestock98GS
Oct 1, 2009 05:10 PM
the.hamburglar
May 26, 2007 04:43 PM
tegon-gsr
Jan 2, 2005 04:09 PM
