brake knuckles
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by hondmywrld »</TD></TR><TR><TD CLASS="quote">i'm running eg dx front brake knuckles currently, can i swap into an dc integra front brake knuckle directly? running a D series, so would the axles bolt up?</TD></TR></TABLE>
If you want to use the Integra brakes you need to swap the whole front brake conversion, including calipers, rotors, pads, etc. Yes they will bolt on and you can still use your stock axles.
everything will bolt up with no problems.
usdm/jdm civic/integra use 32mm axle shaft.
jdm itr uses 36mm axle shaft.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by hondmywrld »</TD></TR><TR><TD CLASS="quote">cool thanks guys i actually want to use the rotors and pads and caliper from the integra because it's bigger</TD></TR></TABLE>
You cannot fit them on stock DX knuckles though, unless you customize them.
nefariousyellow
Aug 16, 2007 08:46 AM
