Won't rev past 2500 RPM?
I have a EF hatch with a OBD-0 B16a swap, and I recently took apart the FITV because the idle was bouncing around. I put it back together and it seemed to be idling correctly (~1500 while warming up), but I realized I didn't plug the TPS back in, so I did that and now the car will not rev past 2500 RPM. I've tried unplugging the TPS and plugging it back in, but to no avail...
Anyone have any ideas?
I think youve might have a problem with your ground in your wire harness around youre ecu area. When u were mmessing with your tps did u disconnect anything from the battery terminal? Ive had this problem before and came to find that it was the ground and fixed it.
iCollectStraws
Feb 12, 2010 09:42 AM
DC5ftmfw
Sep 28, 2006 04:42 AM
