Exclamation help!!! my cv axle keeps poppin out
Old Mar 6, 2008 | 11:25 AM
crxskater25's Avatar
Default Exclamation help!!! my cv axle keeps poppin out
i just put in new ones in and everytime i pop it back in it comes right out once i drive it for like a block or two... could this be the tranny or maybe cuz its lowered???
Old Mar 6, 2008 | 12:29 PM
Johnny-Red's Avatar
Default Re: Exclamation help!!! my cv axle keeps poppin out (crxskater25)
Its completely popping out?
Go outside and look, have someone move the wheel back forth, lower and raise the car, and look for yourself. Check to see if you put everything back together rite
How low is your car? I know it being lowered would put more stress on the actual CV from being at a different angle, but to pop out completely?
You F'ed big somewhere along the line, axles don't just "pop out".
Is there a pin that holds them in? I haven't pulled em on mine all I know is from Subaru's had a pin the holds em in.
Old Mar 6, 2008 | 01:49 PM
93civiceg6's Avatar
check to see if your hubs still have the gold ring in the center most times when swap are done they remove that ring so the b series axles will seat properly but when people put single swaps back they forget about this ring so it causes axles to pop out
Old Mar 6, 2008 | 03:02 PM
progress's Avatar
Are you certain you got the right axles? I replaced my driver's side axle on my RT4wd wagon and the guys at the parts store gave me the wrong one. even after I returned it saying it popped out everytime, they insisted it was the right one. Ended up getting the right one from another store.
Old Mar 6, 2008 | 06:20 PM
nineohnine's Avatar
Default Re: (progress)
the wrong axle is also what happend with mine.. teh guy we bought it from was tired of the "axle getting effed up" turned out the 3 times he had it fixed the wrong axle was used.. got the right axle and never happend to us since...
Old Mar 6, 2008 | 06:30 PM
Jerel's Avatar
Default Re: (nineohnine)
try putting the cutter pin at the end after you tighten the 17mm bolt.
Old Mar 6, 2008 | 07:15 PM
tunerkid7's Avatar
Default Re: (Jerel)
all seals in? making sure you didnt push the seal out when putting the axle back in
martn53
18
Jan 8, 2010 09:01 PM
Jdm John
Dec 12, 2009 12:51 PM
DualCamEJ
May 17, 2009 02:23 AM
keepitngga1
Dec 21, 2006 05:00 PM
type Gendy
Jan 19, 2003 06:18 PM
