si wiring problems
Old Mar 6, 2008 | 07:35 AM
(760)doogie's Avatar
Default si wiring problems
hey, i bought my si with a jdm b16a swap in it and i spun a rod bearing after like a year so its sitting in my driveway. i decided to build a poor man's type r which is almost done and im doing a wire tuck. the problem is that the people that did the swap did a poor job with the wiring so ive decided to clean it up. i pulled it all thru the firewall and unloomed everything and saw that the part of the harness that has all the sensors for the map and eacv and those sensors that go in the back part of the engine bay is messed up. they used crappy speaker wire and horrible connection so when i pulled it through a couple wires came undone. this part of the wire harness disconnects for the rest of it. so my question is. is this connection called the jumper connection? since its all messed up i decided to hit up the junk yard to find one because it will make life a lot a easier because i dont need to touch that part of the harness.
Moshpitmike93
Feb 24, 2019 03:36 AM
Hatch3d
Jul 1, 2015 03:59 PM
1 Civic I
Jan 13, 2011 05:00 PM
fOmaNPu
Sep 16, 2002 10:08 AM
