Port&Polish = Lower CR??
Old Mar 6, 2008 | 06:04 AM
Eg6DR's Avatar
Default Port&Polish = Lower CR??
HI guys, I have a quick question, Im building my b18c1, and just got a complete built gsr head and valvetrain from portflow, I was thinking of runnin p30 .50 oversized pistons from rs machines on my block, with oem headgasket, which would put me about 11.5-11.7 CR, the other day I went to a shop where there was this tuner, and I told him about my plans, he said to get CTR pistons if I want to run that kind of CR because with the port and polished head work, that be knocking about .5 from the CR.
Normally with CTR pistons i'd have 12.2:1 CR but because of the P&P head I'd be running around 11.7; this is what the guy told me but I wasnt that sure, tried doing a search but nothing came out.
Old Mar 6, 2008 | 06:10 AM
b19coupe's Avatar
Default Re: Port&Polish = Lower CR?? (Eg6DR)
Unless Tom opened up your combustion chambers, your compression ratio will be unchanged. Stick with the P30 pistons; PCT pistons are not great.
Old Mar 6, 2008 | 06:12 AM
mar778c's Avatar
Community Builder
Community Influencer
1) Don't get hung up on compression. Ask you self this question, does higher compression make your head flow anymore? Compression is a 2nd order effect. Having a higher flowing head is what is actually important.
2) Don't switch to CTR pistons in a GSR, there are many reasons not to. Search you find the answers as to why.
Old Mar 6, 2008 | 06:40 AM
Eg6DR's Avatar
Default Re: Port&Polish = Lower CR?? (mar778c)
Im still also debating if I should go with Skunk2 pro1 or pro2 cams... what you think?
here's the setup:
Edelbrock 65mm TB
Edelbrock performer X IM
Complete built head and valvetrain (portflow)
P30 .5 oversized pistons
GSR rods
Balanced crank
Hytech Replica Header
Modified by Eg6DR at 11:27 AM 3/6/2008
Old Mar 6, 2008 | 07:27 AM
blacK_Dc4's Avatar
hmm .. if it was my setup , id choose pro1's . I would think the Pro 2's would perform more efficiently with a 2.0L
PLATANOLOCO
Oct 30, 2011 07:26 AM
. WAAS_SAPPENING
15
Jun 12, 2006 06:51 PM
Spyderman4g63
Apr 27, 2005 01:23 PM
DYI01
Mar 20, 2002 01:47 PM
junjun
10
Sep 12, 2001 06:48 AM
