Opinions on Ebay OBX oil pan for H22
Old Mar 6, 2008 | 02:32 AM
djnikko's Avatar
Default Opinions on Ebay OBX oil pan for H22
I was wondering if anyone has had any fitment issues with the OBX oil pan, Ive been looking at the moroso item but for the price the OBX doesnt seem that bad. I just need a little more ground clearance in my H22 CRX
Cheers
Old Mar 6, 2008 | 03:51 AM
subydoored's Avatar
Default Re: Opinions on Ebay OBX oil pan for H22 (djnikko)
i say go for there is no moving parts in oil pan i dont see why it would be bad
Old Mar 6, 2008 | 04:55 AM
98vtec's Avatar
moderator emeritus
ebay
Old Mar 6, 2008 | 05:30 AM
djnikko's Avatar
Default Re: Opinions on Ebay OBX oil pan for H22 (98vtec)
counterfiet possibly? conterfiet OBX? I doubt it very much.
If you know what your buying ebays proven fine for me in the past. Other people might have other opinions though
Is anyone using an OBX oil pan, did you have to modify it in anyway when fitting?
Old Mar 6, 2008 | 06:37 AM
98vtec's Avatar
moderator emeritus
its obx. stick with the stock pan if you dont have the money to shell out for something that is built properly.
Old Mar 6, 2008 | 09:52 AM
Slow_BB6's Avatar
Hopefully it seals!
Old Mar 6, 2008 | 10:13 AM
Hawkze_2.3's Avatar
Default Re: Opinions on Ebay OBX oil pan for H22 (subydoored)
You could take a chance on the OBX....but I personally would never do it.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by subydoored &raquo;</TD></TR><TR><TD CLASS="quote">i say go for there is no moving parts in oil pan i dont see why it would be bad</TD></TR></TABLE>
I'm pretty sure they put a trap door baffle in the Moroso pan...
Old Mar 6, 2008 | 10:26 AM
Acidcrakker's Avatar
Default Re: Opinions on Ebay OBX oil pan for H22 (Hawkze_2.3)
Isnt the OBX oil Pan bigger than OEM? Im pretty sure it is. I think its meant to hold 5.5qts of oil.
Old Mar 6, 2008 | 10:35 AM
djnikko's Avatar
Default Re: Opinions on Ebay OBX oil pan for H22 (Acidcrakker)
You could well be right i'll re-check the advert, im just wanting an oil pan with better ground clearance. I have heard shitty stuff about OBX fitment but it seems they cant have survived this long selling unless they sold the odd functionable item.
I might consider chopping my stock pan an inch or so, if anyones done this it would be good to see pics or have any info. Im guessing chop and weld but enough so the oil pickup can do its job still.
Cheers
Old Mar 6, 2008 | 10:38 AM
Chopping your h22 oil pan, will caue you issues. Make sure you make the right changes to the right ammount of oil that is needed. 4.7 qts is how much it holds OEM. If you make it smaller, its gonna eff with your oil pressure, and you wont have a functioning Vtec.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by djnikko &raquo;</TD></TR><TR><TD CLASS="quote">
Cheers </TD></TR></TABLE>
Old Mar 6, 2008 | 10:40 AM
Hawkze_2.3's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Acidcrakker &raquo;</TD></TR><TR><TD CLASS="quote">Isnt the OBX oil Pan bigger than OEM? Im pretty sure it is. I think its meant to hold 5.5qts of oil.</TD></TR></TABLE>
Yes, the Moroso/OBX pans hold more, but they also give better ground clearance because of the 'kicked-out' design.
Old Mar 6, 2008 | 12:32 PM
ProjectBB6's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Hawkze_2.3 &raquo;</TD></TR><TR><TD CLASS="quote">You could take a chance on the OBX....but I personally would never do it.</TD></TR></TABLE>
You must not have herd.. there lsd rocks
Old Mar 6, 2008 | 12:37 PM
Hawkze_2.3's Avatar
Default Re: Opinions on Ebay OBX oil pan for H22 (ProjectBB6)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ProjectBB6 &raquo;</TD></TR><TR><TD CLASS="quote">
You must not have herd.. there lsd rocks </TD></TR></TABLE>
Yeah, once you take it apart and re-torque all the loose bolts
Old Mar 6, 2008 | 12:45 PM
Si Speed's Avatar
If you're worried about ground clearance, either raise the car or sell it and get another car. Mine is so low that it won't even fit over the pit to change the oil, I have to do it myself even if I feel too lazy, and I still have no problems with the pan hitting anything. I know there's other members on here with their car an inch lower than mine, slammed, and they don't have issues either so I don't see why you would.
Old Mar 6, 2008 | 01:25 PM
Default Re: (Si Speed)
My last Lude I had, It had a 3 inch drop and I destroied One Oil Pan. Dip in Road, the End
Prudz_lude
Oct 20, 2009 10:18 AM
Rob97'SH
Jun 1, 2007 10:47 AM
Rob97'SH
May 26, 2007 03:14 AM
Aaron.Hillman
Mar 3, 2004 09:02 AM
Mighty Mintos
May 24, 2003 11:49 AM
