RS,GS,LS
Old Mar 5, 2008 | 07:24 PM
jr408's Avatar
Default RS,GS,LS
how can you tell which one is ls rs gs on the years 1998-2001?
Old Mar 5, 2008 | 07:42 PM
JoePSI's Avatar
Default Re: RS,GS,LS (jr408)
3G '97-'00 Integra Type R B18C5 1797 10.6:1 195hp@8000RPM/130lb-ft@7500
3G '94-'00 Integra GS-R B18C1 1797 10.0:1 170hp@7600RPM/128lb-ft@6200
3G '94-'00 Integra LS/RS/GS B18B1 1834 9.2:1 142hp@6300RPM/127lb-ft@5200
Gen III
The RS doesn't come with electric anything, but you can get as an option looks and windows and I believe no ABS available.
The LS comes with power windows and locks. It also has ABS and Moonroof. The RS and LS both come with cloth seats.
The SE which was ONLY made in 95-96 is basically the GSR without the suspension and engine upgrades. It comes standard with sunroof, leather and power everything. It also comes with ABS. It is also common that is car is MOSTLY, but not always, found in automatic tranny. Also the 1995 SE got the GSR rims which are perhaps one of the most popular rims for the Integra.
The GS was the "twin" of the SE but wasn't released until 1997, I believe, after they stop making the SE (Special Edition). Once agian they are the GSR but without the gooddies.
All these cars have the B18B1 engine in it that pushes out 140HP @ 6300 and 124lbs. @5200. This engine is the NON-Vtec 16 valve 4-cyl. DOHC. Redline=6800
The GSR has a moonroof, power windows and locks, 15" rims. It came with the B18C1 engine which pushes out 170HP@ 7600 128ltbs. @6200. This engine comes with VTEC (Variable Valve Timing and Lift with Electronic Control) Redline=8000
Also earier years of the GSR, leather seats came as an option. In 1999 leather then became something standard in the GSRs.
For All model Integras, except the Type R of course...Front Brakes Ventilated, 10.3 in. disc type Ventilated, 11.1 in. disc type
Rear Brakes Solid, 9.4 in. disc type
Also there are some differences in the model years of 1994-1997 and then 1998-2001. Some cosmetic stuff such as bumpers, headlight, bumper lights, tail lights, valve cover.
Lastly you have the 1994-1995 OBDI ecu and then the 96+ OBDII ecu chip. Idealy everyone claims OBDI is much better, but after reading some research OBDII is just as good just it has some more restrictions, but could be easily modded to be overlooked.
New and improved G3 integra spec sheet
first lets cover specs that are common to ALL MODELS of this generation:
ENGINE
Powertrain: Transverse front engine, front wheel drive (FF) with equal length halfshafts to reduce torque steer
Engine Block: Aluminum alloy with cast-iron cylinders
Cylinder head: Aluminum Alloy
Emission control: 3-way catalytic converter
Tune-up Interval: 100000 miles, 160900 km
BODY/CHASSIS
Front Brakes: ventilated, 10.3 in. disc type
Rear Brakes: solid, 9.4in. disc type
Steering: Rotary-valve, variable power-assisted rack-and-pinion
Weight Distribution(f/r): 64/36
Stopping distance (60-0mph): 143ft.
RS,LS,GS,SE
ENGINE
Engine code: B18B1
Engine type: 1.8l, 4 cylinder, 16 valve, DOHC.
valvetrain: 4 valves per cylinder, belt-driven, dual overhead camshafts
Horsepower (hp), SAE net: 142@ 6300RPM
Torque (lbs-ft), SAE net: 124 @ 5200RPM
Redline: 6800 RPM
Bore X Stroke: 81mm x 89mm (3.19 in x 3.50 in)
Displacement: 1834cc (112 cu in)
Compression Ratio: 9.2:1
Induction System: Programmed Fuel Injection (PGM-FI)
Ignition System: Electronic ignition
Body/Chassis
Coupe
Front Stabilizer Bar: 22mm
Rear Stabilizer Bar: 13mm
Wheels: 5.5jj x 14, steel or 6.0jj x 15, cast aluminum alloy
Tires: Yokohama P195/60 R14 or Michelin XGT V4 P195/55 R15
Turning Circle: 34.8 ft.
Sedan same as coupe except:
Rear Stabilizer Bar: 14mm
Turning Circle: 35.4ft
Performance
RS,LS,RS,GS,SE 4spd, automatic
Accelleration (0-60 mph)(0-96 kph): 8.5sec.
1/4mile run: 16.8 sec
Skidpad 0.76g
Slalom (100ft) 57.5mph
Fuel Economy (city/highway): 24/30 mpg
RS, LS, GS, SE 5spd manual
Accelleration (0-60 mph)(0-96 kph): 7.6sec.
1/4mile run: 16.1 sec
Skidpad 0.76g
Slalom (100ft) 58.9mph
Fuel Economy (city/highway): 25/30 mpg
GS-R sedan/coupe
Engine
Engine Code: B18c1
Engine type: 1.8l, 4 cylinder, 16 valve, DOHC with Variable Valve Timing and Lift with Electronic Control system (VTEC)
Valvetrain: 4 valves per cylinder, belt-driven, dual overhead camshafts with VTEC
Horsepower (hp) SAE, net: 170 @7600 RPM
Torque (lbs-ft) SAE, net: 128@6200 RPM
Redline: 8100RPM
Bore X Stroke: 81mm x 87.2mm (3.19 in x 3.43 in)
Displacement: 1797cc (110 cu in)
Compression Ratio: 10.0:1
Induction System: Programmed Fuel Injection (PGM-FI) with dual-stage intake manifold
Ignition System: Electronic ignition with knock sensor
Body/Chassis
Front Stabilizer Bar: 24mm
Wheels: 6.0jj x 15, cast aluminum alloy
Tires: Michelin XGT V4 P195/55R15
Turning circle: 34.8 ft (coupe) 35.4ft (sedan)
Performance
Accelleration 0-60mph (0-96kph): 7.2 sec
1/4 mile run: 15.5 sec
Skidpad 0.80g
Slalom (100ft): 62.8mph
Fuel economy (City/Highway) 25/31 mpg
TRANSMISSIONS
4-speed automatic
1st 2.722
2nd 1.468
3rd 0.975
4th 0.638
Final drive 4.357
reverse 1.954
rs,ls,gs,se 5-speed manual
1st 3.230
2nd 1.900
3rd 1.269
4th 0.966
5th 0.714
Final drive 4.266
reverse 3.000
GS-R 5-speed manual
1st 3.230
2nd 1.900
3rd 1.360
4th 1.034
5th 0.787
Final drive 4.400
reverse 3.000
Taken from
http://www.superhonda.com/foru...9578/
http://www.superhonda.com/foru...6391/
Old Mar 5, 2008 | 07:47 PM
kellogg97rs's Avatar
I believe there was just a thread about this.
http://www.team-integra.net/se...D=731
The RS didn't come with a spoiler, power locks, ABS, and a sunroof
The LS had a spoiler, power locks, ABS, and a sunroof
The GS is the same as the LS, but Leather came standard as did alloy wheels, and Sedans had Chrome trim around the windows and came standard with alloy wheels
EGh22aEG
Oct 13, 2008 03:54 PM
midwesta
Jul 4, 2006 05:03 PM
skiptomylou
Feb 28, 2006 07:57 PM
Milano95
Oct 8, 2001 08:58 PM
