Best way to tap into my valve cover?
I was going to just drill a hole of the size of the fitting i was puting into it, and tap it the size of the thread i was going to use...and then screw it in. Is there enough metal in the valve cover? will it hold? will i come across problems doiong this? lmk. My other options were to drill a hole and jb weld it in or just weld a nut on to it and do it that way. but id like to do it the 1st way if possible to make things easyest. lmk guys thx
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Import_spoon »</TD></TR><TR><TD CLASS="quote">What are you tapping the Valve Cover for?</TD></TR></TABLE>
im taking a wild guess but im sure hes planning on running some fittings to a catch can...
vtec.dc2
Welding / Fabrication
Aug 1, 2006 05:03 AM
